Headlight bulb replacement - Bighorn
Let me try to share a video with audio of the headlight fan noise. Quite audible actually with the engine off. For those of you with Supernova v4s are they that loud for you too?
Thanks a lot!
I've seen some people have no issues with fan noise and others like this. How is the noise compared to say....a cell phone vibrating? Can you still hear it inside the cab while driving?
It’s a hum you’ll hear as you walk up to the truck before starting.
Cannot hear it at all if engine is running, all I hear is Hemi goodness inside and out:
Has anyone found any switchback LED turn signals anywhere yet that do not need resistors or any additional wiring? I know Diode Dynamics has a pair for $70 with the extra resistors, but they're also on backorder 4-8 weeks.
Wow I got mine yesterday from diode dynamic. Try calling them?
Hmm, will have to give that a shot...but I also REALLY don't like to mess with wiring. Hoping to find something with resistors built-in.
Super pissed at headlight revolution. Wasted 3 hours outside to find out they sent me one wrong pwm module... they said I’ll have my new one Tuesday... wasted money paying a shop to install these. SUPER DISLIKE the company so far... btw it’s possible to fit everything in but verrry time consuming
That's annoying. You install from the top like the HR video shows or did you go through the wheel well liners?
From the top. My hands are swollen from banging them up trying to install these pos leds.
anyone know if this is the harness that controls my blinker bulb? Im attempting to swap my blinkers and it requires splicing the blinker wire and ground. Thanks ahead!IMG_6475.jpg
anyone know if this is the harness that controls my blinker bulb? Im attempting to swap my blinkers and it requires splicing the blinker wire and ground. Thanks ahead!View attachment 17527
Yes that's the one. I don't know why I couldn't see the picture earlier
Sent from my MI MAX 3 using Tapatalk
go through the wheel, you'll save a lot of time and pain
you the man! Do you have lasfit low beams? headlightrev sent me wrong modules so im considering switching to lasfit. Thanks
Nope, haven't switched out any bulbs up front yet.
My only concern with these switchbacks is that the truck uses the turn signal light as DRL, and these bulbs have this warning:
"2. Since these bulbs built-in Intelligent Temperature Control, if you use for a long time (a few vehicles maybe 2-5 minutes, it depends on year/make/model and temperature) may happen hyper flash, please turn off and cool 1-2 minutes, they will work normally again."
Keep us posted on what they respond with on your email.
For anyone wondering, @kingkasc and I have both reached out to LASFIT and gotten the assurance that these switchback turn signals should work just fine on the 2019 RAM 1500, just make sure to select the CK socket.
You can use promo code DPFLED5 to get a few bucks off. I ordered a pair of bulbs today and they should be here mid-week.
