- Jul 25, 2020
1/2" should be rightAnyone know what size tubing they used to connect to and from the can?
I have some 1/2 inch tubing but I think it's too small for the fittings.
Plan on taking a swing at installing my can tomorrow after all pads and oil on my wife's Acadia. Guess ill find out then, it didn't look like what I had would fit, i'm used to using barb fittings and it looks like this needs clamps.1/2" should be right
The Mishimoto I bought came with hoses and clamps. Which catch can do you have?Plan on taking a swing at installing my can tomorrow after all pads and oil on my wife's Acadia. Guess ill find out then, it didn't look like what I had would fit, i'm used to using barb fittings and it looks like this needs clamps.
I have a Team RXP catch can(s).The Mishimoto I bought came with hoses and clamps. Which catch can do you have?
Nope, no issues with that.You ever had any issues with the clamps not securing tight enough to keep it from seeping out? I had that issue on my 2013 F-150 until I heat sealed some Ford snap connectors to the hoses.
Sounds like you have bad clamps or fittings.You ever had any issues with the clamps not securing tight enough to keep it from seeping out? I had that issue on my 2013 F-150 until I heat sealed some Ford snap connectors to the hoses.
Twin turbo pushes a lot more pressure. I didn’t want to cinch them down too tight and crack the plastic barbs. Once I put the Ford snap connectors on, I didn’t have any more issues.Sounds like you have bad clamps or fittings.
Kind of like quitting smoking...it's never too late.Late to the party on this but...are these worth installing at about 48K in miles or has that ship already sailed?
We run "oil rebreathers" on our marine diesels and the amount of "catch" is astounding. Now, granted, those motors hold close to 30 quarts of oil each.Anthing to keep that unwanted oil from burning in the combustion chamber is better than nothing. I don't know if it's the placebo effect but I added a catch can and removed the carbon filter from the stock air box several months ago and it seems like the truck gained a mile or two per gallon. There is definitely no added power felt
Actually, there does appear to be some blow by in the mixture caught as it has an odor of gas. I’ve also seen some pretty oiled up intakes on several hemi’s, so to me that’s the greatest benefit. With port injection, the valves should stay pretty clean with or without.I personally think the cost of whatever catch can is used is worth it. People use the term "blow by" but that's not necessarily the correct term. Blow by is usually when oil gets past the piston rings into the combustion chamber. The catch cans catch oil that's created by the pressure built up in the crank case. Pistons go up making pressure in the combustion chamber but the pistons also go down which creates pressure in the crank case. The PCV (Positive Crankcase Ventilation) system is used to vent that crank case pressure. In most cases the PCV system usually vents the pressure into the intake and inevitablely into the combustion chamber to be burned for emissions and environmental reasons. Engines burn gas, adding oil to that mixture will reduce the efficiency of the burn so reducing the amount of oil, however small, can only be better for the engine.
Millage | Mini or Reg | Amount removed (in weight) | Quality of liquid removed |
24,032 | Reg | Minimal | |
27,621 | Reg | 5oz | Caramel color oil |
29,950 | Reg | 8oz | Half water, half black oil |
37,015 | Reg | 7oz | Black oil |
