SAURKRT
My biggest disappointment is that I didn't make the switch to Ram from GMC sooner...
But, here are my run on minor items;
- E85 use would be nice (not in my area, but would be good for others) in mid-west.
- When taking calls in Ram, UConnect should turn down heating fan, for noise reduction.
- Would like the thigh support to be a bit better in seat, also option for seat to go higher, or wheel to go lower, hard to see 7" info center behind wheel settings I choose.
- Brake pad monitoring would be nice.
- Shorter fuel mileage tracking, 25, 50 miles, etc.
- Doors should all unlock when putting truck in park.
- Turn signal light on mirror side of both side mirrors, allowing cars on your side to see if you are turning, second lane, etc.
- Elimination of SiriusXM channels you don't want to listen to.
- iWatch alert from UConnect app (better sense of if truck started, doors locked, etc.)
- Larger spare tire, 18" with 22" tires kinda a goof.
- For Black Out edition, put black lug nuts and black door moldings on.
- Ram rear mats should have lift up option for smugglers hatches.
- Where is the rubber mat for a 5'7" bed with RamBox?
- Eliminate antennae in 7" cluster, taking up too much room for actual band names, song names, channel info, etc.
Added, no “oh crap” handle above passenger doors. and a wider mirror (make it more of rectangle to see more of the rear view...probably done to see more of the view out the windshield, but can't see the rear corners of the truck very well.
OK, first thought - good thing you're not OCD besides...
A few counters:
2. No thanks. Comfort trumps convenience every day. If I'm in a situation where answering a call is not feasible because of ambient noise, I don't answer it. OR, change the ambient noise (move to a quieter room, turn down the stereo system, or even turn down that super noisy ventilation fan).
6. I can see wanting that for an option - but in no way should it be an unchangeable default. But maybe you never lived in NYC...
7. Yours doesn't do that?
10. Do you normally ride around on your spare tire?
