What is this sorcery???
MannymanX
5thGenRams Supporter
AzZona
Just came across a Ram ad on my fb feed... looks like just the inner LED lights on the low-beam are on... what is this??? Can I do that too?
Snofire
WI
The outer LED DRL are on, it's just the way the picture is. But yes you can turn the outer lights off in the TazerDT.
MannymanX
AzZona
I'm taking about this light:
The low beam has 2 light modules that creat a rectangle when on:
You can definitely see in the first picture that only the inner module is on and it looks like a small square
Snofire
WI
If, indeed, this is a photograph. It wouldn’t surprise me if the image is computer generated.
I would not be surprised by that but also wonder if that is a setting that could be changed in the Tazer?
MannymanX
AzZona
I have AlfaOBD.. better than Tazer... I hope it's something I can do, I really liked it haha
kenthelawnguy
is this not the driving lights that can be turned on for daytime driving through your settings?
MannymanX
AzZona
Yes, These are the low beams... same light actually(Daytime Running Lights)...
But when you turn the low beams on(or the DRLs) it turns both modules on, As shown here:
In the picture, Just the center module is on...
I've never seen just the center module on, it's always both of them that are on...
bpwj76
LA
What I want to know is if there is a way to make the top and bottom accent LED's bright like they are when remote start is active. When the headlights are on, they are dim. When you deactivate the DRL's, in the daytime, they stay on and are slightly brighter (I think) than they are when the headlights are on. Then they are bright when you remote start.
So it seems that the accent lights have 3 levels of brightness. I want to make them the highest level of brightness, like when remote start is used, during the day when headlights are off.
Jimmy07
Honorary Site Supporter
Have you (or anyone else) witnessed this behavior in person? Those headlight part numbers are the same for 2019-2021, and the wiring to those headlights is the same on The schematics across those years. I have the BCM configurations of a 21 rebel and a 19 rebel, and when comparing the DRL configuration settings, they are the same. That only leaves that maybe it’s a rendering picture that displays the lights incorrectly.
