Installed my 6112s ... Measured both sides and for some reason one is higher then other with both sitting on the same setting![]()
I hope so lmao. It is the driver sideWhich side sits lower? I believe the drivers side sits lower on these trucks because of the fuel tank and other components.
Driver's side rear always sits lower by 1/2'', or so. I personally hate it. I didn't notice it at first. But, now, I can see it every time I look at my truck, from certain angles. Gas tank, smas tank, You'd think there would be a way to correct this. Or, compensate right from the factory engineering. But hey, what do I know? I'm just a guy who forked over $50k+ for a truck that leans.Installed my 6112s ... Measured both sides and for some reason one is higher then other with both sitting on the same setting![]()
damm so does that affect puting bigger tires lol? i may have to go up one more seting then![]()
btw its the front driver side not the rear Front measures 38.5 and front measures 38Driver's side rear always sits lower by 1/2'', or so. I personally hate it. I didn't notice it at first. But, now, I can see it every time I look at my truck, from certain angles. Gas tank, smas tank, You'd think there would be a way to correct this. Or, compensate right from the factory engineering. But hey, what do I know? I'm just a guy who forked over $50k+ for a truck that leans.
Ok, sorry. Got caught up in a rant. Probably should have read your post more carefully.btw its the front driver side not the rear Front measures 38.5 and front measures 38
Both are set to same notchs and i tightened everything up the same ...Ok, sorry. Got caught up in a rant. Probably should have read your post more carefully.
That seems odd to be off like that in the front.
Looks awesome!Installed the S&B cold air intake. I really like the look and man is that filter huge!
Thanks!Looks awesome!
Did you remove the heat shield from the underside of your hood? Looks like the hood vents are functional now, I've wanted to do something like that. Do you have any issues with water or anything getting into the engine bay?
Damn you, now I just might have to get one myself. I see you took the hood liner out and it's good to know the hood vents are actually functional. I may do that also.Installed the S&B cold air intake. I really like the look and man is that filter huge!
Been looking for a while trying to determine which cai to get. Liked the looks of this one over the rest and it’s nice knowing it is enclosed.Damn you, now I just might have to get one myself. I see you took the hood liner out and it's good to know the hood vents are actually functional. I may do that also.
Truck's fuel tank huh? I thought it was my fuel tank that caused this!Which side sits lower? I believe the drivers side sits lower on these trucks because of the fuel tank and other components.
Came to appreciate just how convenient it is to load heavy items in the bed with the MFT and air suspension.
Also, not sure my AC is getting cold enough now that we are in triple digits...
Seriously considering ceramic tint on the windshield to cut down on the greenhouse effect a bit. I was hesitant because I don't want blur or starburst effect, but now I might just do it to keep from melting.
