Today was an installation day with The Abyss. First was the LUYED LED reverse lights. I used the 5-pin CURT harness, marine solder connectors ( heat-gun activated solder/shrink wrap, effective and easy), and probably 9 zip ties to secure all the wiring. Everything is clean and out of the way.
Next I installed LED bed light strips. I wanted the same functionality as the BUG lights, and I didn't want to install prox switches or anything complicated. Although I initially didn't want to cut into OEM wiring, the ease and security of the solder connectors changed my mind. The BUG bracket at the left includes a switch at the bottom and a light above it. I removed the left tail light, which has both Torx screws and push-in fasteners (gently pry out the center lock with a screwdriver tip, then pull out the fastener). The BUG harness has two connectors on the back side. Bottom is for the switch, and top goes to the light. The light is powered after the switch, so using the red/black wires here gives you the same functionality as the light it connects to. You have to cut away some fabric wrap to get to the wires. The LED strips have their own switch, so if the BUG lights are on, you can turn off the LEDs if you like. Currently, I have it mounted with double sided tape behind the round hole by the tie down loop. I will probably replace the original switch with a nice round one that fits in that hole with a proper nut on the back side.
Finally I set up my tonneau cover and my cargo bar / bin storage. I bought the ratcheting cargo bar from Harbor Freight (Haul Master brand) and a pair of 27 gallon totes from Costco. With the tonneau cover, you end up with a locked trunk, so I can securely store items I don't want in the cab while I'm shopping. Further, I have rain protection from the tote covers and the tonneau as well. I'll be able to toss groceries in there, or camping gear for example. The bar keeps the bins close to the tailgate without sliding.
The tonneau is an Extang Solid Fold 2.0. It's the only brand stating compatibility with the 6'4" bed / Multi-function tailgate. The 3 folding panels are thick / tough, not easy to cut through. They're also able to hold 600 lbs evenly distributed. The rear latches are spring loaded handles. Just tug them down to release the cover, then like most others, it's a tri-fold. Easy peasy.
