Kyles
- Dec 15, 2019
20 x 10 Fuel Rebel 6s with a 33 x 12.5 Falken Wildpeak At3W
Your Truck looks great! Love the Roll Bar/Rack. I was thinking about getting their shorter rack version or the Go Rhino Sport Bar 2.0As of yesterday and last week Ive added steps, bed liner coating, decked storage system, rear seat storage and my new rack. Just waiting for my lights to arrive to mount to rack.
Great job on the install of the running boards. They will serve you well.Got my running boards installed finally!
Ok I'm very curious. Can you describe these tapes? Its a fantastic look for the grill. I've got the same color and grill... Link?Needed a change . Grill tapes
Looks great. What kind?Got my running boards installed finally!
Very nice! Thanks3M Scotchcal Electrocut Gloss Adhesive Graphic Vinyl Film 12" x 24" Roll 2-Pack w/Hard Yellow Detailer Squeegee (Burgundy) https://www.amazon.com/dp/B07BSXQXTZ/ref=cm_sw_r_cp_api_i_naB.EbERAEBNB
Once you get this ,you can cut and stick in to your grill.
Dune bashed in Qatar...
Sent from my SM-G986B using Tapatalk
I'm sure it'll be fine forever, just always scares me doing stuff like that. I'm going to end up running the ignition wire I need into the cab and into F66 I believe it was that was an ignition fuse.It is, but if you use a fuse tap to properly hook it up, you will blow the lesser strength fuse going to your added equipment before blowing your ECM/PCM fuse. I don't have much electrical experience, but from what I have learned from watching many car audio type videos, it is safe to do with a fuse tap. I have personally had no issues, but it is fully reversible in seconds if I were to have any issues. Also there is an onboard replacement fuse should it blow while I am in transit somewhere.
Looks great-I have a similar set up but not the divider. Do you have the part # on the divider? Is it an extender or just divider?My bed divider/extender showed up (purchased on this very forum, thanks!). Finally completing my dream triforce of truck bed awesome (rambox+BedRug+divider)
Where did you get your bed rug? I have been looking but with RamBox I haven’t found anything.My bed divider/extender showed up (purchased on this very forum, thanks!). Finally completing my dream triforce of truck bed awesome (rambox+BedRug+divider)
That's a good option. I was trying to avoid going through the firewall, and someone on here had suggested F60. To each their own though. Good luck with your project.I'm sure it'll be fine forever, just always scares me doing stuff like that. I'm going to end up running the ignition wire I need into the cab and into F66 I believe it was that was an ignition fuse.
And can you get a side shot? With the camera at the height of the boards. I’d like to see how high and close to the cab they are. Thanks!
