As of yesterday and last week Ive added steps, bed liner coating, decked storage system, rear seat storage and my new rack. Just waiting for my lights to arrive to mount to rack.
Your Truck looks great! Love the Roll Bar/Rack. I was thinking about getting their shorter rack version or the Go Rhino Sport Bar 2.0
Got my running boards installed finally!
Ok I'm very curious. Can you describe these tapes? Its a fantastic look for the grill. I've got the same color and grill... Link?
3M Scotchcal Electrocut Gloss Adhesive Graphic Vinyl Film 12" x 24" Roll 2-Pack w/Hard Yellow Detailer Squeegee (Burgundy) https://www.amazon.com/dp/B07BSXQXTZ/ref=cm_sw_r_cp_api_i_naB.EbERAEBNB
Once you get this ,you can cut and stick in to your grill.
Installed Mopar Corner Bed Step
Dial Shifter Trim Plate, Etched Brushed Stainless Steel: https://www.amazon.com/gp/product/B07Z5C9JD2/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
USA Valve Stem Covers: https://www.amazon.com/gp/product/B083WMYP4F/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
AVS Hoodflector: https://www.autoventshade.com/avs-21953-hoodflector-hood-protector
Vitodeco Genuine Leather Remote Control Key Case Covers: https://www.amazon.com/gp/product/B07N53H66X/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
EXXTREME Console Safe(R) for 2019-2020, Low Profile, for Longhorn & Limited, w/ Electronic Lock: https://www.lockerdown.com/i-146-ex...he-longhorn-limited-only.html?ref=category:11
Hellwig Rear Sway Bar and Hellwig Rear Adjustable End Links: https://www.hellwigproducts.com/products/search-by-vehicle/?Year1=2019&Make=Ram&Model=1500
Tazer DT: https://www.zautomotive.com/product/tazer-dt/
Tazer settings used:
  • auto-fold/extend mirrors w/ ignition off/on,
  • remapped DRL to amber turn signals,
  • kept fog lights on w/ high beams,
  • enter address into NAV while moving,
  • turn on backup camera w/ turn signals,
  • turn on front/rear camera at any speed
It is, but if you use a fuse tap to properly hook it up, you will blow the lesser strength fuse going to your added equipment before blowing your ECM/PCM fuse. I don't have much electrical experience, but from what I have learned from watching many car audio type videos, it is safe to do with a fuse tap. I have personally had no issues, but it is fully reversible in seconds if I were to have any issues. Also there is an onboard replacement fuse should it blow while I am in transit somewhere.
I'm sure it'll be fine forever, just always scares me doing stuff like that. I'm going to end up running the ignition wire I need into the cab and into F66 I believe it was that was an ignition fuse.
My bed divider/extender showed up (purchased on this very forum, thanks!). Finally completing my dream triforce of truck bed awesome (rambox+BedRug+divider)
Looks great-I have a similar set up but not the divider. Do you have the part # on the divider? Is it an extender or just divider?
That's a good option. I was trying to avoid going through the firewall, and someone on here had suggested F60. To each their own though. Good luck with your project.
Looks great. What kind?
And can you get a side shot? With the camera at the height of the boards. I’d like to see how high and close to the cab they are. Thanks!
Its a Dominator D6 by GoRhino, they have $50 rebate deal going on right now. Here is the picture from side. It sits pretty close to the cab but not that tight. I am loving it!
I don't have all the part numbers handy, but It's the divider / extender, as well as the parts needed to make it actually function as the extender on the 2020 (details in this thread: https://5thgenrams.com/community/threads/rambox-extender-hooks.1773/)
Where did you get your bed rug? I have been looking but with RamBox I haven’t found anything.
Ordered it from Amazon: https://amzn.to/31LOrDY
The description says it's for the prior gen, but if you scroll back a page or two, I made a youtube video of the install and verified it does fit pretty well (again, thanks to guidance from posts I found here)
