Here's a random one for those with Ramboxes. I found an 18" tool tote bag that fits the perfect width and height of the Ramboxes. You can't have it right in the center because of the latch area, but this will work perfect for an on-the-go tool kit etc. Now to throw some real tools in it...
Finally got my swingcases back from getting lined and put back in. You have 4” of clearance towards the back and 5” towards the cab. I added some pictures below.
Damn, these things look so much better after they’re lined.
Another heads up if you pull the trigger on the swing cases. Call undercover direct and buy a set of replacement lids. The lids get scuffed up over time (this may not bother you but it drives me crazy). For $50 they will send you 2 replacement lids with hinges installed and an additional 4 hinges with the hinge extraction tool. This should more than cover you for the life of the truck. My stock of swing case parts in my garage is getting excessive but I’ve got brackets, lids, and hinges in case of an issue in the future.
Those look great!
also enables someone(or yourself) to leave then on indefinitely if the switch is not turned off.
Well that's a possibility with almost anything. I tend to know what myself or anyone else does in my own truck.
Really? Which speakers did you go with? I noticed a major difference in the highs and overall clarity. Same with the rear door speakers. Keep in mind that the polarity is reversed on our systems, so you have to swap the wires around to get the best sound quality.
Did you use the Metra adapters?
I used BedRug part # BRI-BRT09BXK, which is technically made for the older body short bed with RamBoxes. It ended up fitting near perfect. I'm not sure why BedRug doesn't just market that model as being compatible with the newer body with RamBoxes. I got mine on Realtruck.com and chatted with them for a slight discount. Here's the Amazon link for it...
This is interesting info - thanks for sharing. I was looking to just get the BedRug mat, not the full liner. I think I may order the one for the Classic model and see how it fits.
Yes. I bought the speakers from Crutchfield and they included the adapters.
I did the Infinity Reference speaker, fronts, rear ceiling, 2 way in rear doors and the woofer from the component system in the front doors , I just did plug and play with the metra adapters.
Yeah. Without them switched I noticed a bit of distortion.
SMH, I am not pulling all these panels again. You would think that Metra would have it configured properly
I didn’t switch any polarity and I switched all of my dash, doors and overhead speakers and I don’t notice any distortion or issues.
I will agree that mine seems fine as well
I seem to remember reading that’s on the Alpine system and affects the door speakers only if I recall, I’m sure someone will correct me if that’s incorrect.
Sorry that my truck is a little dirty
I believe we all need a little faith in times like these.
Funny, I noticed it more with the dash speakers than the doors.
Maybe it was the dash, as I said I could be wrong but I do recall something regarding polarity and the Alpine.
Decided to jump on the mud flap train. I stalled my Husky mud flaps this afternoon. I don't plan to off-road anytime soon, so I just used the outside screws and the sticky on the inside for now. Time will tell if I need to add that additional retaining clip that they provide.
View attachment 55435View attachment 55436View attachment 55437View attachment 55439
Using same method I installed Husky on my rebel about 10 months ago and.............. No issues.
