The front is fighting bad. First the upper control arm would not disconnect from the upper ball joint. I tried a 2 different forks and it was a no go then I went to my ball joint kit. The bolt was so long I had to cut in order to use the tool.
I got my new kit for spring tool and I'm really surprised how well it works for a cheap tool. Now I can't get the shock bolt off the top hat its all rusted and jacked up. Impact isn't working and I cant hold the shaft in place. Do I just cut the dust shield so I can grip the shaft and keep it from spinning?
Leave spring pressure on the strut when loosening the bolt. Will help keep the shaft from spinning. Once the nut starts to loosen, then compress the springs.
As for ball joint, never use a pickle fork. All they do it destroy the ball joint boots. Hopefully you have new UCAs already especially since you cut the threads. All you need to do is loosen the ball joint nut, don't completely remlve the nut, then smack the **** out of the spindle, by the ball joint, with a hammer. It will pop loose.
