The front is fighting bad. First the upper control arm would not disconnect from the upper ball joint. I tried a 2 different forks and it was a no go then I went to my ball joint kit. The bolt was so long I had to cut in order to use the tool.
I got my new kit for spring tool and I'm really surprised how well it works for a cheap tool. Now I can't get the shock bolt off the top hat its all rusted and jacked up. Impact isn't working and I cant hold the shaft in place. Do I just cut the dust shield so I can grip the shaft and keep it from spinning?
Leave spring pressure on the strut when loosening the bolt. Will help keep the shaft from spinning. Once the nut starts to loosen, then compress the springs.
As for ball joint, never use a pickle fork. All they do it destroy the ball joint boots. Hopefully you have new UCAs already especially since you cut the threads. All you need to do is loosen the ball joint nut, don't completely remlve the nut, then smack the **** out of the spindle, by the ball joint, with a hammer. It will pop loose.
I do have new control arms or I wouldn't have used something that destroys them or cut them. I have several removing tools and have never had to cut a bolt like that before but a bigger tool wouldn't have fit it in the same space.
I tried putting as much pressure on the hat/top to jamb the shaft as I was comfortable with but it still spun. I fear springs a little too much which may be the cause of that method not working but I've had success with it before. I'm going to try and grab the shaft with vice grips after another attempt of putting more pressure on it. Its coming off today! 🤪
The other option is to buy a set of the pass through sockets and ratchet. Then you can get a tool on the hex of the shift above the nut, to hold the shaft when you break the nut loose.
This weekend, I painted the gray plate on the bottom bumper.
I also added 9 inch offroad light to the bottom bumper.
Like I said before, I didn't want to remove the bumper to add the KC mounts or something like that.
Since the bumper is made of steel, I had it attached there. Made 1/2 inch holes, bought the brackets from Home Depot.
Maybe I had less fear making a hole in the bumper because I may buy a high clearance bumper in 2 years.
Next Mods:
1. Suspension!!! ( I have it leveled, so now I need to buy proper lift kit and don't know if I will go for the 8112 Bilsteins)
2. More Powerrrrr ( Cams and turbo charge it)
Then maybe the offroad bumper, for now, I really liked how it looks. Especially because it is work from my own hands and my creativeness.
Pictures below:
The hat or perch actually has rubber in it. I guess its to fight vibration, but I wonder if its something that should be replaced at some point?
not needed but might as well replace them because if they break/ come apart in the future you gotta do it all again.
I cleaned them up the best I could and have them in the oven now. I need to make it drivable quicker than the parts will get here.
I have a feeling there will be some other suspension changes in the future so Ill get them now.
The struts perform exactly the way they drove, boat like. They do very little either way
Fought with the Uconnect .....
You had to try and set up Android Auto "well" on your smartphone. Give all permissions and choose "open automatically."
Subsequently, it will be enough to have the BT activated. In my case, UConnect has never missed a beat with either Ram 2025 or 2022. Try it!
Sent by SM-F766B on Tapatalk
well if you upgrade to ones that come in as all-in-one units (like the Fox 2.5 or Kings) then you won't have to worry about it lol
well the saga continued today.
took the truck on a 40 minute commute to work. Going there at around noon time was fine, but in the evening when I drove home the cab side power cut out again (this is for the loop I added: breaker, dedicated power & ground to cab to run DC-DC charger for Delta 2 and HAM radio).
Checked all work done last week, nothing was loose or appear to be cause of breaker tripping.
Decided it may be the Victron DC-DC charging continuous draw and the Start/ Stop not playing well together. Turned off Start/ Stop and no more tripping for the 30 minutes drive home.
So... I made a label and stick it under the ign switch to remind myself to disable Start/ Stop :ROFLMAO:
we shall see how that goes tomorrow.
edit:
don't want to make another separate post but I sat in the truck planning the Christmas - New Years trip since I have ~10 days off...
Meeting friends in LA, go to Gold Butte NV and then Grand Canyon North again, then take Highway 50 ("The Loneliest Road in America") then make my way to Leslie Gulch, then back to LA.
a whopping 2253 miles (more for sure) round trip... Don't know how northern NV will be this time of the year...
open to camp suggestions, attractions, things to see, etc north of St. George and along the route to Leslie Gulch.
edit:
I just added those two Oregon locations 2 days ago in my 'want to go' after Revere Overlands video
It has worked fine since March. The phone received an update the other day and it became glitchy while trying to connect and then would not at all yesterday.
  • Back
