sPod or switch-pro only
sPod because it's the same company as BD
switch-pro because:
- it's made in USA. Support your fellow Americans.
- it's the only switch panel that I, as an installer and offroader/ overlander, can trust with my life. I abused mine for 5 years going through snow, mud, dust, ice, water, heat, and vibration and my switch-pro works just as good as day 1. death valley in summer, mojave in summer, AZ in summer, stoddard wells in summer, anza in summer, big bear when it's snowing, mojave road river crossing, etc all no problem.
- loads of functions: secondary triggers, output dimming, choices of power by battery or ignition, strobing, flashing, momentary on, bursting, bluetooth remote, voltage readouts, temperature read outs. one key on/off for multiple output, and much more!
- yeah it's expensive but you install this correctly this will last a long time
As an installer I'm gonna advise you against cheap chinese panels like auxbeam.
- In my career of installing lights, panels, weboost, head units, and other stuff, I have never seen anything with a failure rate as high as auxbeam.
- Auxbeam is the only panel that I've installed that have dead panels right out of box. Multiple times.
- Auxbeam is also the only panel that I've installed that have died within a year. Also multiple times.
- Auxbeam is also the only panel that I've had to charge for install, then charge for uninstall to swap over to Switch-Pro. Also at least 3 times.
- Auxbeam is also the only panel that I've had to troubleshoot for problems months after I install and run the lights "because it suddenly stop working"
TLDR:
Switch-Pro is something you can depend your life on. Granted it's a bit pricy but for the performance and value of what it does, it is a bargain.
sPod is from the same company that owns BD, their stuff looks decent but I have no personal experience with.
Auxbeam is trash and stay away. You get what you pay for but be prepared to spend time and money to chase down problems or replace it later down the line.
