well today new glasses went back in. Mopar glasses front and rear.
glass guy forgot to turn off the truck so... my battery went flat for the first time since 2022 lol. jumped it, drove it and most of the warning lights went away, and then CEL remained. Cleared it and all is good.
tomorrow dropping off the truck to tint the new glasses.
I THOUGHT about mine today......that's all I can do. Have owned it for 49 days, the last 29 days its been in the shop. Digital gauge cluster is bad, we are past the ETA on a new one. Who knows. 2025 Big HornView attachment 204220View attachment 204221
I bought mine with the cluster problem you have. it was replaced within the week while I used my trade in as the loaner lol. 5k miles later no issues. its worth the wait.
Here you go
My truck is a limited so I started off placing the truck in Off-Road 2 so I didn't need to jack it up
Tools:
1/2" or 3/8" 15MM Socket
1/2" or 3/8" Impact gun
(I used a Kobalt 1/2" gun the 1st time, it took the drive shaft flange bolts off easily, they are very very tight and have blue Loctite on them
I bought a Milwaukee 2960-22 Combo on sale at Home Depot a few months ago so I used it. The reason for the Milwaukee is that it is 1/2 the size of the Kobalt 1/2" gun and gets into the space between the drive shaft and the muffler much easier and can use a shorter extension because its far smaller than the big gun. You can do this with a 1/2 hand tools but you will need a big ratchet, those bolts are on there. The impact gun will make life far easier.)
swivel
(I use these from harbor as they don't move very much)
3/8" 8"-12" extension drive
angle cutters (to remove Dust Cover boot)
CV Boot clamp tool
Grease and CV Boot Clamp
1. Set the emergency brake (I chocked the front wheels too)
2. Open emergency neutral switch door and pull the orange Manual Neutral lever placing the trans in neutral
3. Lift the rear of the truck if yours is too low, mine is normally in Aero Mode so its too low. Off Road 2 lifts it high enough for me to get under and keep the tires on the ground.
4. Slide under the rear of the truck (I went under Infront of the rear tires so I was facing the diff) with your angle cutters, impact wrench, extension, swivel (at the end of the extension) and 15MM socket
4A. Optional but probably a good idea, use a white grease pencil and mark both the end of the dust boot and the driveshaft with a line for reassembly
5. Cut the rear or the front dust boot clamp and remove it, you don't need to remove the both clamps, just one. I removed the rear clamp leaving the boot on the front section of the driveshaft.
6. With your impact wrench and socket, remove the four 15mm bolts form the rear of the driveshaft where it attaches to the differential, you can get to all 4 bolts without having to rotate the diff pinion flange.
7. This is important, notate the drive shaft u joint ears orientation, they all need to be facing the same direction on reassembly, note the two yellow circles, otherwise you'll get a vibration on acceleration
8. The rear section of the drive shaft is 2 pieces, slide the rear section of the drive shaft out of the front 1/2 of the rear section. It will come apart with minimal effort.
(the above pic is just for illustration, I did not (you do not) need to remove the entire drive shaft or even only the rear section. All you need to grease is the rear male end of the drive shaft)
9. Take the rear section and place it on a work bench and check for wear or damage, wipe it clean then regrease
10. Regrease the entire length of the splines with some extra grease towards the front. As you reinsert the male shaft into the female receiver shaft, the grease will be pushed back from towards the rear of the shaft.
11. Reassemble making sure that you orient the U-Joint yokes the same as the front yokes, see image in step 7.
The easiest way for me was to rotate the drive shaft still attached to the trans to the point were all the u-joint yoke ears were pointing straight down, I then took the newly greased section and oriented it so its rear u-joint yoke ear was also facing down and inserted it into the dust cover then into the female section of the shaft.
It doesn't matter if you reassemble the shaft 180° out from the way it was (bottom u-joint yoke is now top or vice versa) the two yoke sides are weighted the same, mine had two 1.60oz weights on both sides yoke ears so it was identical however you would probably be smart to use a white grease pencil and mark both the end of the dust boot and the driveshaft.
12. This was the most difficult step, once you've aligned the driveshaft halves, you will need to push the male shaft into the female end, the schaffer high tack grease makes that difficult.
I placed one foot on the axle tube and my two hands around the tail end of the drive shaft and pulled it together until it collapsed enough to get on over pinion yoke of the differential.
13. At this point, re-check your yoke alignment and ensure that all 3 u-joint yoke ears are aligned (pointing straight down). It is very easy to get the rear section one spline off so double check it.
14. Once you're satisfied with the alignment, place some blue Loctite (242) one the bolts, snug the bolts up so the driveshaft flange sits flat on the diff pinion flange then tighten with your impact wrench.
15. Torque driveshaft bolts to 81ftlbs
16. Install a new dust shield clamp and clamp with your tool.
That's it, looks like a lot but it took an hour the 1st time I did it and 20-30 minutes this time. Took it for a test drive yesterday and it was butter smooth, zero sensation at stops or with auto stop/start. Its so smooth now that I have to look at the tach/AutoStart icon to see if its off and no bumps at stops lights.
I know this post is a few years old, but thanks for posting this. Been dealing with a clunk since I bought the truck last year. I thought it may have been the u joints, but that wasn't the case.
After seeing this post, I got some red tacky grease and went to town.
I've only driven it a little since doing this, but haven't experienced the clunk at stops/starts since greasing the yoke.
I thought you murdered someone with it :-)
um not sure that's grease...
more like evidence
First new set of tires on my Night Edition Limited after putting 34k miles on the OEM Pirello Scorpions (which I've never been a fan of on multiple other SUVs that came with them). I drive pretty much exclusively on the road (and mostly highway), so went with the Michelin Defender LTX M/S 2. I've really only had one significant drive so far, but the ride seems good and noise level is great... pretty much as expected.
Same truck (2024) and same Pirelli tires. Mine are about shot at 16,000 miles. Disappointed in the tread wear and the lack of tread warranty on new vehicles. According to the warranty no tread wear on Pirelli’s installed with new vehicles, but tread warranty if it is a replacement tire. Dumb.
Will probably go with Michelin too.
My factory tires were wore out at 30K too. Crazy how they put crap tires on from the factory. That’s when I decided on a small lift and 35s :)
Well I didnt buy slayer new but the tires on it are factory OG. I am knocking on 57k and still have life left in them. I take off with ambition in life corner hard and break late.
Years ago when going to car meets I used Turtle wax ice on my z28, so decided to try it in my bright white Bighorn, was impressed how much more shine the white popped. Now I ordered another TW product to add extra shine on top of the ice. For price and ease of use, think it will be my goto lazy detailing job. Took me 20 minutes to do entire truck. For around $10, I can do truck many times. Going to try tw pure shine graphene misting detailed on top, then final will be a coating of McKees hydro blue ceramic coating, I bought a package deal of it awhile back, so have it already.
New KO3's, new brakes all around, tranny fluid / filter change, oil and fuel filter. It was a day.
Just got my KO3s last Friday took it for a 3 hr ride and I’m vey impressed. Very quiet and tight around turns better ride. Had nittos ridge and there is a difference in sound and ride imo. Hope you like em
