19BlueStreakSport
The bars ordered from dealer are installed different then the TRX. What you don't see in the pictures is a stake pocket mount. So on the bars you get from Mopar they are held on with 2 bolts at the back and then a bracket that bolts onto the side bars where stake pocket is and slides into the stake pocket and bolts using a clamp from inside.I'm a little concerned about how you'd mount this (after modifying). I only see two large holes on the downturn flanges - no other attachment points. On my Rambar, there are three bolt holes along the top surface (inboard of the posts), as well as a single side-mounted hole on the downturn flange. So each side of my Rambar has 4 bolts.
Unless I'm missing them, I only see two holes on each side - at the rear end (which isn't great). Kinda makes me wonder how these are supposed to mount on the HD Rams.
I heard somewhere the TRX are bolted at the top because the truck was design with "jumping" it in mind and as rigidity. Now sure how true that is.
See picture of bracket in stake pocket. So each side has 3 bolts on this.
Yeah, you got the right plan. Much easier to just modify the center tube after it's removed from whole assembly. This way it all fits back together. No other way to do it without fabricating a new center tube, or finding an old guy at the muffler shop who will just cut and weld in a new tube "good as new". LOL.
Yeah I'll have to take a look. As the bed rail brackets seem like they may have a different angle on it then the one for the 1500s. The brackets for the 1500s look flat, whereas the one I have for the 2500s looks like it's on a downward slope. So test fitting and stuff will need to be done. As the bar may not sit how it is designed. As long as it follows the lines of the truck I'm OK if it sits a little different.
