NordicNevs
- Feb 16, 2019
Got a chip in my windshield- right in my field of vision.
The worst
Please post what they do to fix the tailgate cables... there are several posts about it around the forum. Oh and I’ve got the same prob.
Just catching up in the forum but an answer to your question is this:
All trucks no matter the brand that have a dampened tailgate will have this problem. I had a 2016 F-150 that was even worse than my 2019 Ram. Neither one got right when opened. It was all reliant on the dampener.
Looks great, did you lift or level the front, what size tires?new BLACK milled pro comp wheels for our 2 WHEEL DRIVE Big Horn : )
BEFORE:
AFTER:
UP CLOSE:
Thanks, I was looking to level my 2WD lonestar and this shows me what it will look like. This combination gives you an extra 3 inch ground clearance in front which is plenty for my driving situations. Curious as to your perception of ride and handling vs stock ? Are you primary city/highway and are those tires noisy at high speed?I would assume the taller tire will feel better vs low profile stock, even with a more aggressive tread.Thanks! Rough Country 2 inch level, Pro Comp tires 295/60/20, Pro Comp wheels
Before anything:
Made a “cargo bed divider” View attachment 19419 View attachment 19420 View attachment 19421 out of:
Leftover white door trim (been in garage for 2 years), cut pieces of plastic rocker panel trim that fell off my previous vehicle (07’ Durango, traded in for the Ram) and a Ram sticker I got in the mail. Good use of a free hour on my day off. LOL
yes, I bought a trailer adapter that gives you another hookup behind and underneath for a clean smooth installI like the light bar. Does that wire into your trailer harness?
Thanks. They are the stock rims only 18’s. I’m a little different then most, I like more rubber then rim. I do a lot of camping and fishing so my rims normally get a decent amount of wear. So when I saw these I knew I wanted them. The truck is a Laramie.@Bufo Nice pic. What rims are those? Stock 20's? They look different. What trim model is your truck?
Nice. I do camping also, pulling a TT so I went with the 20's instead of 22's for more sidewall. Are the tires rated an E?Thanks. They are the stock rims only 18’s. I’m a little different then most, I like more rubber then rim. I do a lot of camping and fishing so my rims normally get a decent amount of wear. So when I saw these I knew I wanted them. The truck is a Laramie.
