Dookie
This was the main reason why I did what i did.
I'll have to enable that one. I didn't know it displayed like that in the center screen.![]()
Just asking what you did to keep spots on with your brights. You answered by saying what you did reading and purchasing module software and cable etc. More than what I would want to do at this timeRead a 53 page post, buying the software, buying the module and cable needed, deciphering of the post made, watching some videos on how to manipulate the software and execution of what i bought and learned.
If you are asking the specifics of the AlfaOBD, i can share that too. Not sure what exactly you ate asking.
Agreed, and I think it looks sportier without. Thanks for sharing your thoughts.Your truck looks much better without. The deflector makes it look like your hood isn't closed.
You need to get the flush mount AVS hood protector like the one I have on my Limited. It sits tighter to the hood and grill.Your truck looks much better without. The deflector makes it look like your hood isn't closed.
That does look better, but I assumed OEM would be a better fit and a more exact chrome-match. Now I’m just not sure I want one there at all. Looks pretty good on yours with the white paint, though.You need to get the flush mount AVS hood protector like the one I have on my Limited. It sits tighter to the hood and grill.
I forgot to mention that when I coated my running boards I discovered that you can't lower the truck with the running boards deployed.
Air ride will, not respond if the running boards are deployed.
Also won't raise if hood is up
Well it doesn't use much unless you are towing. I fill up mine usually at truck stops. It a lot cheaper than buying by the box for sure.No, lol. I’d rather know I’m getting quality DEF though. I don’t trust the dealer enough yet for that. The only reason I had them fill it with gas is because they use the same Shell station that I do since they don’t keep diesel on site.
I’d love to do that, but the closest one to me is 56 miles away, which equals 1hr and 26mins away without any traffic. That’s not really feasible. I am thinking about returning the bluedef platinum I have and just using walmart or tractor supply def.Well it doesn't use much unless you are towing. I fill up mine usually at truck stops. It a lot cheaper than buying by the box for sure.
It does remove some hold structure from the wheelwell liner, but I found punching a couple holes and adding a zip tie or two through the plastic takes care of that.I’ve only seen his posts and pics of the removal so I figured I’d give him credit for the idea.
Someone’s always gotta have a critical comment when someone has a nice thing to say.Pioneering it? If just comes right out. You relocate a couple Christmas tree push in wire loom holders and you are done. Removed .one without anyone having to show me how
It’s worth the wait!Scheduled ceramic coating for Thursday. They have to keep the truck for 4 days to ensure the coating cures properly…![]()
Just went over 14,000… took delivery June 23,2021 with 23 miles… feel your painMy '21 that I got back in August is about to go over the 12,000 mile mark (had 9 miles when I took delivery). At this rate It will have more than 30,000 before it's 1st birthday.
Looks great! What bug/stone deflector is that? It looks nice and tight to the hood. From the one pic it looks like AVS maybe?Here are a few pics of the turn signal DRL, kinda hard to capture what it looks like in person versus on a photo though.
And I may do the Accent light drop out and only have it like this later on, just seeing what I like best and fun to play with it.
This is not accurate. I always start washing my truck in OR2 with the running boards deployed. After I’ve washed the wheels, wheel wells and lower portions of the truck, I press “entry/exit” mode on the FOB and the truck lowers all the way down so I can wash the upper part and roof. The running boards stay deployed the whole time, no problem.
That looks sweet...does it impede your view from inside? Can you share a pic?New decal![]()
