What cell phone? I believe they are 5 volt (2.5amp). My Pixel 5 shows "charging raidly" but my QC is not the true standard.Anyone know if the USB-C ports in the 2021 or 2022 trucks is ~3.0A. or higher? Something that would be a "quick charge" for the cell phone?
Thanks guys
I have a Motorola Edge Plus 21 nothing fancy. But it 3.0amp to fast charge anything below it is a trickle charge for my Motorola.What cell phone? I believe they are 5 volt (2.5amp). My Pixel 5 shows "charging raidly" but my QC is not the true standard.
For a Pixel phone, at least the 5, it fast charges at 18 watts (9V/2A). All kinds of stuff gets me charged up pretty quick. Now that I've got the placement right on the wireless charge pad, even that thing does a good job of putting a decent charge on it.I have a Motorola Edge Plus 21 nothing fancy. But it 3.0amp to fast charge anything below it is a trickle charge for my Motorola.
Mark,I understand your sentiments, however that's why you have us!We are always here to provide the additional support and do all that we can to keep you in the know. If you are ever in need of any additional support down the road, please do not hesitate to tag us or reach out privately.
Mark
RamCares
Probably just so... I gave up and just put a power brick in the AC outlet in down in the bowels of the console. LOLi came here looking for answers but believe I discovered the issue. My theory is, all the usb ports are attached to stereo system as an input and powered by the stereo. Because of this, the usb ports will have a lower amp feed then if you had a standalone usb port that just connected to the battery. Too bad because I don’t need all those ports attached to the stereo but I need them to provide enough juice to do wireless charging from my phone mount.
I have a new meter from Klein Industries arriving tomorrow and as I too am curious as to the output of all the USB connections in my 2019 Ram 1500 Limited; I will run full tests tomorrow and post the data for all to see. This should close out this thread and help anyone else wondering the answers to these questions.Resurrecting an old thread. As the newer iPhones are only rated to charge at 7.5w, this is what I would expect to see.
What I HAVEN'T seen is anything definitive that tells us exactly what the power output potential is of the USB-A and USB-C ports. I would really like to know how many amps I can get from each port and whether or not there are any advantages to using a USB-C to Lightning cable for both power and data delivery (e.g. for CarPlay performance). I do use a USB-C to Lightning cable, but I would like to know if there would be a dropoff in power or data if I had to switch to USB-A to Lightning.
@RamCares, can you provide this information? I've looked through the owner's manual and the UConnect manual, and there is nothing in either that provides power/data rates. TIA
Nice video, you made me order the Klein... lolOk folks… all done… here’s my video on the power of the onboard USB-A & USB-C ports onboard the 2019+ Ram 1500.
EDIT: in the video I state the center USB-A port (port 5) offers more voltage then the other USB-A ports; but it actually offers more Amperage (almost double) with the same voltage.
Is this a marketing promotion for Klein?
Great info, I've always been curious.
Thanks for sharing!
