No problem.
I had two different leak scenarios. The first symptom was water stains in the rear corners of the headliner. Past experience told me the rear cab mounted stop lamp assembly was leaking. Dealer service replaced the lamp assembly.
Leak returned about three months later, technician retightened the four mounting screws per a TSB.
About six months later there were water stains across the entire rear of the headliner. Technician worked on it for four hours, determined that window was leaking. Unlike others, there were no frame cracks on mine.
Glass replacement company called. Window replaced about one week later. Two days after replacement, leak at rear headliner.
I inspected seal at top of window and it looked like the glass replacement company missed applying sealant at top of window frame directly under the lamp assembly. Ram technician confirmed. Glass replacement company and tech. worked almost entire day to repair, eventually resealing the top of the window frame and lamp assembly.
It's been almost a year since all this transpired and...I'm afraid to say this...it has not leaked since.
By the way, the headliner stains were removed successfully after each repair by dealer service. They used some kind of fogging device.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 047660 miles.
