Ram1500DS
Has anyone had the driver side floor, carpet and insulation wet? There has been a lot of rain in Texas lately. The rubber floor mates kept the water from drying out.
thanks
thanks
Thanks for the help. After closer inspection the water only seems to be on the drivers side floor. Top of rear air duck was wet. No water under the front soundproofing by the pedals. Sheet metal does not fit by left seat rail(I was able to slide a plactic wire tie into the opening for at least nine inches), but the passenger side looks the same but did not prob it. Is there a good link for the TSB for this truck.Has anyone had the driver side floor, carpet and insulation wet? There has been a lot of rain in Texas lately. The rubber floor mates kept the water from drying out.
thanks
I found the leak origination point and the exit point. The water is coming in at the point where the roof rail meet the windshield rubber, looks to be not seated correctly. The water makes it way down the front door pillar and comes out thru a gap in the welded seam. Actually above the small gap you can see in the photo. Off to the dealer in the AM.Thanks for the help. After closer inspection the water only seems to be on the drivers side floor. Top of rear air duck was wet. No water under the front soundproofing by the pedals. Sheet metal does not fit by left seat rail(I was able to slide a plastic wire tie into the opening for at least nine inches), but the passenger side looks the same but did not prob it. Is there a good link for the TSB for this truck.
I just checked mine and yup I have the same leak on the driver side floor. Here are pictures showing the passenger vs the driver side. The driver side looks very similar to your picture Did you get it fix ?I found the leak origination point and the exit point. The water is coming in at the point where the roof rail meet the windshield rubber, looks to be not seated correctly. The water makes it way down the front door pillar and comes out thru a gap in the welded seam. Actually above the small gap you can see in the photo. Off to the dealer in the AM.
I have an appointment Oct. 7. I don't know if the water is coming in at the point where the roof rail meets the windshield rubber or if the windshield seal further down is bad. I'm hope full its no the windshield seal. The dealer needs to do his own water test then we take it from there. ThanksI just checked mine and yup I have the same leak on the driver side floor. Here are pictures showing the passenger vs the driver side. The driver side looks very similar to your picture Did you get it fix ?
The history in my case is this. It was built on April 2019, and had 151 miles on it after my test drive Sept 17. It sits in my drive way and endured Topical Storm Imelda on Sept 19. On Monday Sept 23rd; I for some reason pulled up the rubber all weather floor mats that came with it. I was able to duplicate the leak with the garden hose using the spray setting pointed directly at the point where the plastic roof rail meets the windshield rubber which is not seated correctly. I can only hope the dealership can reproduce the problem when they do their water test. The floor mats trapped the water in so in was not drying and the back of the mats where wet. Fortunately only thick pad and the carpet got wet for an area about 12 x 18 inches. So the padding wicked the water from the door sill over to the center consul. It should have been leaking from April to Sept. At least the potential was there. Hope this helps. I plan to follow up one my dealer correct everything. ThanksJust out of curiosity. Is this something that happens over time? My truck doesnt leak that i have noticed, but it was sitting on the lot for like 8 months before i bought it. After reading on this forum, i checked the floorboards before leaving with it and didnt see any water and still havent
Hello All: To follow up on the water leak, from months ago. I still have the leak after the windshield was replaced. Going back to the dealer Dec. 6.
Thank you, The truck is at the dealer now. You should also check my post on water leaks. After the windshield has been replaced I still have a water leak on the DF floorHi Ram1500DS,
I am very sorry to hear this. Please know that if you are in need of any extra support while working alongside your dealer, our team is just a private message away and more than happy to help.
Mark
RamCares
