Longhorn5G
- Nov 30, 2018
I hope its that idatalink too! Because if that messy problem happened on its own, im going to be one paranoid person as a 19 ram owner
The jl it is happening to has had some work so I can’t respond to that. But doesn’t have the bypass I do and the results are similar but not the same. Good friends with a Chrysler person he says it’s not isolated. and there has been numerous bcm hardware changes since release on both vehicles. So not sure. Hope the idatalink box is the cause. Because that would be simple. But nothing in life is simpleI hope its that idatalink too! Because if that messy problem happened on its own, im going to be one paranoid person as a 19 ram owner
Did you ever get a reply or fix for this? I have a 2019 doing the same thing.back from the dead - did this get resolved? my truck doing this now, same dtc 's set. it does self-reset after a while. no aftermarket equipment except diablo pcm. tried factory pcm put back in, and problem re-occurs while driving.
