No yet.Have you posted pics of your truck lifted yet?
Here's a pic of my truck with the stock wheels and tires. Measurements are from center of fender to the floor
Driver front 38.5"
Driver rear 40.25"
Pass. front 38.75"
Pass. rear 40.75
That’s how the knuckle”spindle” stops at full steering lock. Not an issue. Just the way it’s designed.Just did my oil change and noticed that my knuckle is rubbing on the rear of my lower control arm on both sides. Anyone else getting this? I have the kit with the TSB extra ring. I haven't heard any clunking or anything like that. Just saw it while changing my oil. Will this cause any major issues down the road?
What could be done to fix this? Would a small amount of negative camber fix this? Any side effects of negative camber?
Swap out the front spings with springs from the offroad package and it will give it another inch in the front.And this had the added spacer? I knew it wouldn’t fully level it but I was hoping for more than that.
Yeah this is with the added spacer.And this had the added spacer? I knew it wouldn’t fully level it but I was hoping for more than that.
Looks great. What size tire is that 275/55/20?Here's a pic of my truck with the stock wheels and tires. Measurements are from center of fender to the floor
Driver front 38.5"
Driver rear 40.25"
Pass. front 38.75"
Pass. rear 40.75
The tonneau is a Rugged Liner HC D6519.$819 on Amazon with prime delivery. They also have one for the 5.5 ft bed. It doesn’t have rails it sits on top of the bed rails and can be removed completely in several minutes. I had a backflip on my last ram and it rattled like mad. This one only has minimal leaking in heavy rain. No rattles and it has lights inside as well. Will share some pics a little later todayLooks great. Would you mind sharing measurements from center cap to fender line?
Yeah. I cant afford bigger tires right now so I'm sticking with the stock ones for now. It doesn't look terrible, but it would definitely look better with bigger tires.Looks great. What size tire is that 275/55/20?
Are you running the 35x12.50R22 on the stock wheel with no rubbing on the cHello All,
Wanted to create a thread for pictures/discussions about the updated Mopar Lift/Level Kit (Part#: 77072424AB) - available early May for the public.
I luckily was one of the first to receive and can verify that it does sit closer to level than the original Mopar-Fox 2" Lift kits.
(Comparing another Ram side by side with the original 2" Mopar lift)
I will compile some side pictures and get measurements on Monday and post them Tuesday, as there are about 4 posts going around discussing this update.
IF YOU ALREADY OWN A MOPAR 2" KIT - please be advised there is a TSB That will allow you to drop off your Ram should you want the additional 1" in the front.
(I believe is free of charge but will confirm for those when I drop off my truck Monday for a detail)
Hope this thread helps, lets discuss!
No wheel spacers? I figured the 12.5" wide tire would rub on the control arm with a stock wheel...Here are some rough measurements (will try to get some precise measurements soon but I know these are close, if not 100% accurate):
- Front center hub to fender: 24"
- Rear center hub to fender: 25 1/2"
Hello All,
I installed the Mopar 2” leveling kit on my Laramie Sport and have mixed reviews on it. I went with Toyo 35x12.5r22 RTs, for the highway/aggressive look.
The good: it looks amazing. Exactly how I wanted it to come out. The rare color combo makes the truck stick out, and road noise is negligible.
The bad: Handling is terrible. Something has to be wrong, the rear end sways as if it’s fishtailing with the slightest wheel jerk, and it doesn’t feel planted as well as the stock setup. Being FOX shocks, I’d expect a better ride, but it’s just not there.
Fuel eco took a MAJOR hit. Averaging 12MPG highway @78mph, coming off of 16mpg, the 4mpg is a huge decrease. To circumvent this, I’ve ordered a Pulsar and a Vararam to be able to input the tire size and increase airflow.
Need to figure out the cause of the Sway, I don’t believe the 35s are the issue, it seems track bar or sway bar related.
I’ll keep you all posted.
Pics for show.
Pics for show.
. Still looks like there is a bit of a rake with the updated spacer... has anyone tried stacking something like a Motofab 1/2” level kit to achieve a more leveled look?Rear coils are not as stable side to side as leaf springs. The shocks primarily control up and down, less so side to side. That and you have moved the center of gravity upwards but without increasing spring rate, the big downside to a spacer. A thicker swaybar will help as will proper air pressure in the tires. Just know a lifted vehicle will lose some stability due to increased cog.I installed the Mopar 2” leveling kit on my Laramie Sport and have mixed reviews on it. I went with Toyo 35x12.5r22 RTs, for the highway/aggressive look.
Pics for show.
Does the Mopar 2" kit use coil spacers or is it a spacer on top of the coil/strut assembly?I installed the Mopar 2” leveling kit on my Laramie Sport and have mixed reviews on it. I went with Toyo 35x12.5r22 RTs, for the highway/aggressive look.
Pics for show.
