- Apr 11, 2019
I don’t see why it wouldn’t work, as the 2022 GT uses the same trans/TCM and it has paddles. If you’re going to try, start with just the paddles and the wheel harness (new harness is necessary to plug in the paddles).Just checked on www.moparwholesaleparts.com and they now have part #'s for everything to change your steering wheel over to a TRX. Part #'s below:
Steering wheel #7FA45NR3AA-$1,052.25
Steering wheel wiring #68529748AA-$57.75
Steering wheel bezel #7EY37TX7AA-$152.40
Steering wheel insert (Bottom middle piece) #7KT01TRXAA-$185.26
Paddle down shifter, left #68446789AB-$54.13
Paddle down shifter, right #68446788AB-$54.13
Total: $1,555.92
As of right now, I'm not sure at this time if I'm going to buy a TRX or install a hellcat motor into my Rebel and keep it? I'm waiting for estimates. If I keep it, I'll buy these parts and change it out. I don't know if you need the wiring harness, but I was going to order it anyway.
Then use AlfaOBD to change the following:
VehConfig 3: Paddle Shift Feature Present to YES
VehConfig 7: Paddles Lock-out Feature Present to YES
VehConfig 7: Shift Feature Autostick / Electronic Range Select Status from ERS to Autostick
Depending if those do it, you may also need to change VehConfig 3: vehicle is an SRT to YES, and VehConfig 3: Chassis Type to 38
