Thnaks. Nice TT, What is your towing experice? I feel you almost reach the limit of your truck.My family of 4 (2 kids) and we have this: https://forestriverinc.com/rvs/travel-trailers/alpha-wolf/26DBH-L/4038
Yeah and that was all just estimates. If you get your truck and it has 1300+ pounds of payload that gives you some more room for a bigger trailer or putting luggage in the truck. Remember, every item you put in your truck that wasn't there when you got it is weight reduced from your payload. You'll have guys tell you "Oh yeah, you can pull a 30 foot trailer with a Limited no problem these trucks can handle it." aren't the ones driving YOUR truck.Just becasue I am not going to tow a lot every year, limited will give me the best daily ride experiece. Thanks for your suggestions, I'll start to looking for loaded TT under #7000
Nice set up, 4500 is the dry weight?No problem towing my Jayco Jay feather 7. About 4500 lbs.
The unloaded weight is 3630 lbs. This is the 2016 Jay feather7 xud.Nice set up, 4500 is the dry weight?
Thanks. I just built mt truck last month. With the limited trim (5.7 hemi with etorque) I would expect the payload rating would be around #1300. I have 3.92 rear end. The combined weight of my family around #400. I have zero towing experience. That's why I am here for learning myself. I am looking for a TT around 25' to 27, is that too big for my truck?
I believe in WDHs- enough I had one for out little 20 foot rPod being towed by a Tacoma. Probably overkill but it gave us peace of mind and worked for our set up. We utilized a Fastway e2- that is a WD and sway... Easy set up.Thanks. That's exactly we are looking for. We need the bunks for sure. How is the quailty of your 2021 keystone? Do you use any WDH and sway bar for towing? I had the air suspension, but I believe the WDH is still an essential. Not sure about the sway bar, since the truck come with sway control right?
I also have towing group and pano sunroof. 5.7 bed, level 1 group, night edition group, anti spin axle. That’s all I have. Thanks and good to know that <30 would be good. Any suggestions for the WDH?What are the rest of the options in your Limited build?
25’ to 27’ is not too big, <30’ long will tow very nicely with good WDH setup
You have to use the WDH anytime your tongue weight is over the truck hitch rating. Most hard side TTs will be above that threshhold. Almost all hitch makers have sway controls available as well. It is a physical addition to the hitch setup. It's job is to reduce sway from the hitch to a comfortable level during "regular" driving. The trucks electronic sway control is an "emergency" control, similar to stability control. Do you rely on stability control in regular driving? Wait, don't answer that!Thanks. That's exactly we are looking for. We need the bunks for sure. How is the quailty of your 2021 keystone? Do you use any WDH and sway bar for towing? I had the air suspension, but I believe the WDH is still an essential. Not sure about the sway bar, since the truck come with sway control right?
I recommend the Equalizer 4-point swayI also have towing group and pano sunroof. 5.7 bed, level 1 group, night edition group, anti spin axle. That’s all I have. Thanks and good to know that <30 would be good. Any suggestions for the WDH?
You have to use the WDH anytime your tongue weight is over the truck hitch rating. Most hard side TTs will be above that threshhold. Almost all hitch makers have sway controls available as well. It is a physical addition to the hitch setup. It's job is to reduce sway from the hitch to a comfortable level during "regular" driving. The trucks electronic sway control is an "emergency" control, similar to stability control. Do you rely on stability control in regular driving? Wait, don't answer that!![]()
Thanks for your input. That’s so helpful. Where to know the truck hitch rating? I assume all 1500 series has the same rating regardless the truck brand? What is the rating with or w/o the WHD? Are they the same?You have to use the WDH anytime your tongue weight is over the truck hitch rating. Most hard side TTs will be above that threshhold. Almost all hitch makers have sway controls available as well. It is a physical addition to the hitch setup. It's job is to reduce sway from the hitch to a comfortable level during "regular" driving. The trucks electronic sway control is an "emergency" control, similar to stability control. Do you rely on stability control in regular driving? Wait, don't answer that!![]()
Thanks for your picks. Those are cool TTs. I do like the Imagine, is this too heavy for my truck?I recommend the Equalizer 4-point sway
You have many options, here are a few
Freedom Express 257BHS
Outback 244UBH
Apex Nano 208BHS
Imagine 2400BH
Beautiful TT. 23’ long is for the living space? The totals include A frame could be 25~26?This is what we have. Kz Escape 231bh. Bunks for the kids, 23' long, right at 4k pounds dry. Pulls great. The perfect size in my opinion. Sure I could probably go bigger, but I like to maintain some buffer room.
Your setup looks awesome. So nice. Looks like you have the limited too? What is your payload? Are you exceed the limitation with your Outback? Any reason you chose keystone Outback over grand design? Sorry I got too many questions, just because of I have zero experienceGrand Design is nice, no the 2400BH is not too heavy. Their 2910BH was our runner-up choice, we decided on a Keystone Outback 291UBH instead.
Exactly. The cabin is 23' and I think overall with hitch and bumper it's close to 27'.Beautiful TT. 23’ long is for the living space? The totals include A frame could be 25~26?
I would suggest attending local RV conventions (normally a good amount occur in the winter months (Jan-Mar) and local RV dealer lots.... Its very important to get inside them, walk around, get in shower stalls, and imagine yourself/your family in it.Beautiful TT. 23’ long is for the living space? The totals include A frame could be 25~26?
