Tony's Rebel
 - Aug 12, 2020
TL 35’ tongue to tail
			I have found the same thing, changed tires and sway bar, helps some but truck is still gets pushed around pretty easyGlad you were able to correct the swaying problems. My 2019 Tradesman Quad 4x4 without air suspension is experiencing the same major swaying issues pulling my 5000lb travel trailer. Unsafe at speeds above 60mph. Forget trying to trailer on a windy day. I’ve adjusted the WDH tension, ball height, tire pressures, weight loading on trailer and truck several times without any noticeable improvements.
One thing I noticed with this truck is the side to side movement when pressing sideways on the rear bumper. With minimal alternating pressure, you can get the front and rear to start swaying considerably. Anyone else able to duplicate my findings? I’ve tried the same test on several other brand trucks and get almost no movement. I’m leaning towards replacing the Bridgstone Dueller HT 275/65R18 factory tires being the biggest issue. Next would be adding the Hellwig sway bar.
Have you set up the WDH per its manual for your RAM? Or did you just swap it over without making any adjustments?I also have very bad sway with my '21 4x4 pulling a 5000lb TT. I used to tow with a 1/2 ton chevy, and it was perfectly stable, even with 305/70/16 tires and completely worn out suspension. No air suspension on my tradesman, and I didn't see in the truck manual how to set up differently for ram WD hitches. Need ideas, because this is a white knuckle ride for me.
Since you don't have air suspension, there's nothing special to do on the truck about setting up the WDH. It's all about transferring the weight back to the front axle and keeping the truck level when hitched up. The hitch height may be the same but spring rates could be different and could be causing issues.I'll have to find the manual for this hitch and redo it; yes, I transferred over. The hitch heights are very close, and I pulled the same amount of bar on both trucks. Not sure if mentioned, I also pulled with no bars (full tongue weight on rear) and just as bad. But am I expecting to see in the hitch manual a different setup for Ram? How could they try to list all the different vehicle and trailer types out there? Are there Energy Suspension bushings available, at least for the track bar?
I agree with the RV dealer hitch installation. Interesting thought on the bar tension as I would have thought the opposite. The sway I experience seems to be mostly with gusty winds. Not necessarily a white knuckle ride in every situation but much more vigilance and small steering corrections required the entire trip.It takes some work to get the weight distributing hitch set correctly and most rv dealers don't have a clue . with the air suspension I've noticed if you put too much tension on the bars it makes the rear suspension too soft and sway is worse much worse .
Glad to see you got the issue sorted out. Going to the Hellwig and a stiffer sidewall rear tire in the thing that made my Ram feel better while towing. One other thing to consider when towing is the trailer tires. Manufacturers put on tires that are soft walled and just barely rated for the weight of a dry trailer. It is extremely easy to overload, and thereby easy to create trailer sway. On roads that are heavily used by semis, the grooves they produce are enough to make even a fiver feel squirmy at times.D
Severe sway pulling toyhauler
Jump to LatestUnfollow
1 - 4 of 4 Posts
D
Dslowell
· Registered
Joined 12 days ago
Discussion Starter • #1 • 4 days ago
I have a 2019 1500 with air ride that starts swaying severely above 60mph.
I have taken it to the dealer multiple times and they have checked everything and say there is no problem with the truck, it is my loading causing issues.
I have tried loading all configurations, dropping, raising ball, aft, forward. Even at 8500, lightly loaded it still does it.
I have weight distribution and sway bars, and have towed this trailer with my 2014 1500 for over 20k miles now, at much higher weights. It still currently tows this trailer now without issues.
Am I the only one having a towing issue?
Any help would be appreciated, Dodge has not been helpful.
Thanks
RAM‘s soft coil suspension, lack of or too soft of a sway bar, p rated tires... all contribute.I did something driving down the interstate today after making some lane changes through some construction, and feeling some away with no trailer. A couple fairly quick back and forths, about 1/4 lane change each, and I was feeling about like I had a trailer swaying around.
Makes me wonder a bit.
Thats a really good point on the tires Trooper. Some are ST rated, others are standard car P tires. Either way it bears examination, as well as air pressures.dslowell, glad to seeyo
Happy towing.
A 35’ trailer which is taller, longer and heavier than the 20’ truck. Classic “tail wagging the dog” issue. We can make a lot of improvements in tow vehicle suspension, tires etc but theres just some physics that can’t be fixed with a long trailer and certain pivot points.I have found the same thing, changed tires and sway bar, helps some but truck is still gets pushed around pretty easy
Of interest, my truck is ORP with the standard C range (2500 lbs) LT tires, Falken wild peaks. P tires for this size are usually 114 or 116 load ranges; approx 2600-2900 lbs. Even with the 9% reduction in rating for truck use, it still is higher than the axle. I realize this may not be representative of sidewall stiffness. That said, I will probably end up with e range tires next, simply because that is where all the choices are.RAM‘s soft coil suspension, lack of or too soft of a sway bar, p rated tires... all contribute.
You’ll likely be chasing this for awhile and spending $$ as well. Just do one thing at a time from the list of upgrades or mods like tires/load range/inflation, adding a sway bar, WD and anti-sway hitches (and adjusting them), your total weight loading, % tongue weight, shocks, air bags etc.Of interest, my truck is ORP with the standard C range (2500 lbs) LT tires, Falken wild peaks. P tires for this size are usually 114 or 116 load ranges; approx 2600-2900 lbs. Even with the 9% reduction in rating for truck use, it still is higher than the axle. I realize this may not be representative of sidewall stiffness. That said, I will probably end up with e range tires next, simply because that is where all the choices are.
I'm Just curious if you did the full WD setup required for this truck. Involves multiple measurements with air ride on and off and measuring distance from ground to fender before and after putting the trailer on. Somewhere in the forum and I believe in the manual explains the procedure and needing to fall within a certain percentages Related to those measurements. Not just a matter of lowering or raising the hitch.... I did mine when I first got it and it tows my 8500 lb TT like a dream.I realize i am towing heavy. I have a Eaz lift wd hitch with sway bar. 2 point. We dont have t storms, thankfully, but really crappy roads with stud grooves in them. I have e rated tires on my 14, and will probably switch to try them on the new truck. But the p tires lasted a while on the 14 and never did this. Tires are jacked up to max pressure, on both the trailer and truck.
It is not so much as a sway issue, as a rear end lateral push that seems to increase in amplitude and cause a steering input that makes it feel uncontrolled is the best way to describe it. It is not feeling like when the front is light and improperly loaded. It is difficult to explain, easier to feel.
I was just wondering if others have had this issue.
D
