IvoryHemi
- Jan 3, 2021
I am about to get my first travel trailer after thinking about it for almost a decade. from what I have read, the ram 1500 auto-leveling air suspension can work great with weight distribution, if and only if you set it up correctly. from what I can tell here are the must do's, at least for the equalizer hitch:
1. start with trailer frame level and truck level at normal ride height and tire jack mode turned ON (which disables any load leveling of the air suspension)
2. trailer ball and coupler need to be at same height
3. based on front wheel well height change, you need to adjust the amount of weight distribution to get back to at least 66% of height change (per ram manual) or up to 100% per equalizer recommendations based on their testing
4. use tow/haul mode which should disable aero ride height mode, (if not do it manually in the settings) which if engaged it would lower the truck at hwy speed and alter (increase) the amount of weight distribution
I find towing better in Aero mode instead of Normal.
