U
		User_55621
Guest
Couldn't this also be done by comparing images of the OEM brackets since folks have removed them from the 2020 & 2021?
			Images may not be good enough for very subtle differences, but it would still be great if people could submit a photo of their OEM brackets.Couldn't this also be done by comparing images of the OEM brackets since folks have removed them from the 2020 & 2021?
Attached is a photo comparing both brackets. The left one is the 2021, the right one is the 2020. As you see, the holes are slightly different. These hole alignments are pulled from the OEM brackets.
I don't think that they're longer, that might just be a perspective issue on the photo.The 2020 bracket looks a bit longer? Although if you compared the measurements from the bend and use that as your reference face, the holes actually appear to be in the same spots at the same dimensions.... not sure why there would be any difference or discrepancies?
what cover are you going with then?View attachment 84705
These are my 2021 Ram Bighorn with MFT, NO Rambox....I received the 2021 Right-On brackets and installed them. They fit like a glove, no issues with installation.
ordered a RetraxPro XR...what cover are you going with then?
i have the pace edwards full metal jackrabbit ,not cheap , requires a key , but works great & looks great !Try Gator brand. I got a hard, folding, locking cover. Awesome quality and fit
					rightonbracket.com
				What's stopping you?I really want to try the BAK Revolver X4s..
they are on backorder for 4-6 weeks. Looked at Lomax also because you can you can totally remove and sounds like they need tweaking more the the RO brackets which were ordered today. Still hoping by some miracle that this gets figured out.What's stopping you?
EXCELLENT Choice!ordered a RetraxPro XR...
Sorry, but I still think the 2020 - 2021 bracket thing is a hoax. Same part number but, the holes are aligned differently??? I just don't believe it. There would be ZERO reason for RAM to change the position of the holes and, if they did, the part numbers would differ.
I could not find your update on this cover. I have gotten the RO brackets and I am looking at the Bak Revolver X4 cover too. Did you have any problems on the install?Thanks to everyone in this thread for all of the great info! Ordered a right on bracket, the recessed screws from amazon, and a Bak Revolver X4s cover along with an Adarac Aluminum truck rack in black. Fingers crossed everything fits together and I'll be a happy camper. Will update with my results once everything comes in.
Just ordered everything Friday, lol. Don’t even have the truck yet! That should be here Monday. Cover should be here today, brackets Monday.I could not find your update on this cover. I have gotten the RO brackets and I am looking at the Bak Revolver X4 cover too. Did you have any problems on the install?
