Patriot blue but the only thing is that no one likes the patriots . ( Cheaters )
Also curious about this new olive color
I do not think the e-Torque system would be neat as advantageous on a engine that makes such high torque at low RPM as th EcoDiesel does...
My biggest concern with start/stop is allowing the turbo to spin down. If the eTorque application also can electrically boost the turbo, that would alleviate that concern.
F1 cars use convention turbos but have electric motor assist for another 160hp or so
I am interested in the night/ dark trim.... if not than the max steel and black.I don’t know about anybody else but all I’m worried about is if I should get a White one or a Silver one!!?
There was a little nugget in the Jalopnik article that alludes to the Ram (in at least one trim) being able to get 33 mpg. Apparently Ram was telling the journalists that you could take an EcoDiesel Ram from Duluth, MN to Dallas, TX on a single tank of fuel. 1,085 miles/33 gallons is approx 33 mpg. So matching or beating the duramax ratings is still on the table...I was a little surprised to hear that GM MPG drops from 33 (2WD) to 29 (4WD). There's also the 10-speed vs. 8-speed difference. Does Ram go for a higher MPG number with a lower rear axle ratio, and then anybody that wants the towing capability will never see those numbers?
So much drama.![]()
