bigdodge
Happy Ram Owner
- Aug 25, 2021
- Location
- southwest. where majority rules
you sure it does not have the active air dam?2021
my understanding it came out in 2019 with the 5th gen rams
Possibly a casualty of the covid chip shortage and supply issues where the factory was "deleting" some features to get trucks to dealers.you sure it does not have the active air dam?
He did say it was factory delete. I see dealers around me that order a few different items as factory delete. They get small credit, and can advertise cheaper prices.you sure it does not have the active air dam?
So I wonder if anyone has taken into account the amount of energy it takes to run the AAD motor. This electricity is ultimately generated by burning fuel. So playing devil's advocate, if you live in a suburban area with a lot of stop signs and 35 and 45 MPH speed limits, the thing is going to be running up and down a lot. Is it possible that mileage and therefore emissions may actually be worse with the AAD under some circumstances?The idea they are pushing is that by reducing wind turbulence under the vehicle (with the air dam and shutters) they reduce the drag coefficient (improve aerodynamics), which improves mileage (lowers fuel consumption), and therefore reduces emissions.
AFAIK, dealers can not request certain items that are part of option packages be deleted. There are many Rams shipped the last couple years with factory option deletes due to supply issues and the chip shortage. Not because they were ordered that way.He did say it was factory delete. I see dealers around me that order a few different items as factory delete. They get small credit, and can advertise cheaper prices.
I've seen them ordered rear under seat storage delete. No chips. That's just one example. Said delete, with a credit.AFAIK, dealers can not request certain items that are part of option packages be deleted. There are many Rams shipped the last couple years with factory option deletes due to supply issues and the chip shortage. Not because they were ordered that way.
You've witnessed them order it in the systems or you saw it on a window sticker?I've seen them ordered rear under seat storage delete. No chips. That's just one example. Said delete, with a credit.
Window sticker, when searching trucks. The inventory site sucks too, shows trucks nowhere close to what is searched. You have to open each one separately. I have clicked on many in the price range, to find out they have options I HATE, but can't eliminate, but missing something I must have, about the same price. I saw on a few, when choosing show window sticker, that they had things listed as delete, with a credit. One of which, was rear under seat storage, which was part of an option package.You've witnessed them order it in the systems or you saw it on a window sticker?
Woah.Alrighty so I owned a 2020 5th gen with the 5.7 hemi and no etorque. I removed air dam and added 34in duratracs. I essentially started getting 14mpg to work driving city where before stock I was getting 17mpg. So airdam + bigger tires + plus off-road tires = 3mpg. Every little thing does equate to 1mpg it seems.
I now have a 2022 3.6l etorque. Stock. Drove it home last night highway. Then to St Patrick’s day event city. Let it idle for 5 minutes started to show my friends. I’m getting 21.5 now. Was 26 when I got home from dealer. I’ll do hand calculations when I hit E.
It was the tires on the 2020. Especially if they are load range E. Had you recalibrated the speedo?Alrighty so I owned a 2020 5th gen with the 5.7 hemi and no etorque. I removed air dam and added 34in duratracs. I essentially started getting 14mpg to work driving city where before stock I was getting 17mpg. So airdam + bigger tires + plus off-road tires = 3mpg. Every little thing does equate to 1mpg it seems.
But if you get the miles for your hand calculations from the odometer, and you haven't calibrated your tire size, you are still using incorrect numbers and will get incorrect answers.Sorry, I misspoke and looked up my previous order. They were 33’s. 275/60/R20. SL rated. 49lbs each. I also never went off the trip computer. I hand calculate everything.
You are right about that. The trucks sit nose low, and the air suspensions lower at speed for better fuel economy. As soon as you modify ride height, everything changes.The only way I think it may help is if you are stock, as the front end is low enough that when it deploys it is close enough to the ground to possibly do what it advertises. But as was posted if all the piece parts net 1mpg, what is the air dams worth .5, .7, who knows. I am lifted 3 inches in the front/1.5 inches in the rear with 34 inch E rated tires and have the AAD deactivated and get anywhere from 16 to 19 on the highway. I read on post that removed both and claimed better gas mileage and I believe the truck was lifted. Try taking the stationary one off for a couple gas tanks and see the difference. You can always put it back on. This should give an indication if it really makes a difference and how much. I did this with the AAD disconnected and did not see any real difference, but again I am lifted with larger tires.
