SnowBlaZR2
Fuel Economy Champion
By the way...it was supposed to be, in case that went right over your head.Lol these comments are always funny to me.
If you read my entire rambling diatribe I was trying to say I use my truck for a million things as you say- a family hauler and a workhorse etc. But I also use it to do things like hauling and towing and still manage to do those things with the 3.21 axle ratio. Basically pushing back against the idea real truck guys ger the biggest rear axle ratio. In the end it is specific to the person and the truck in my experience - in a 3.6 ram the 3.21 to 3.55 makes a bigger difference it seems to me than the switch from 3.21 to 3.92 in the 5.7 trucks and in my work trucks upgrading an F250 to the 4.10 makes a noticable difference in towing with a gas engine. I suppose one of the reasons we all like trucks is there are so many options we'll never run out of things to argue and opine about!I hear this a lot, but what exactly does that mean? Seriously, I use my truck as a truck...sometimes. I also use it for commuting back and forth to work. Or to pick up groceries. Or as a way of getting my family from one place to another. It's a 5 passenger vehicle with a bed. And has some amount of towing capacity. I could say the same about many other types of vehicles. When I was growing up we used the family station wagon to pull the boat to the river. Were we mis-using that car as a truck? Am I not using my truck as a truck when I have 3 or 4 passengers with me but I'm not towing or hauling anything? My truck is capable of doing this, as a truck. In my mind I'm using it as a truck for everything I use it for.
The OP said he will almost never tow anything heavy -All but about 500 miles on my truck are while towing/hauling. I use my 1500 like a truck, which is why I don't have 3.21s.
You know your truck isn't a real truck and there is no way you do real truck things with it because you don't have a real truck 8' box!! I may have a 3.21 but at least I have the 6'4" boxAll but about 500 miles on my truck are while towing/hauling. I use my 1500 like a truck, which is why I don't have 3.21s.
Of course, because he's using his truck like a crossover adventure vehicle or whatever they're calling them.The OP said he will almost never tow anything heavy -
Nobody's perfect. At least I got the gearing right.You know your truck isn't a real truck and there is no way you do real truck things with it because you don't have a real truck 8' box!! I may have a 3.21 but at least I have the 6'4" box![]()
Lol there is always truth behind jokes. Especially with sarcasm.By the way...it was supposed to be, in case that went right over your head.![]()
All you had to say.I opted with the 3.21 for my build
Personally, I think the 3.92 is overrated for most chores. Sure, if you tow near your limit a lot, you're going to want the 3.92 and if acceleration means more than fuel economy, again, the 3.92 seems to be the most popular option.
I opted with the 3.21 for my build and I do plan to tow from time to time. I've read through the Engineer's guide and although it has great numbers, people have come to believe the 3.92 is the end-all-be-all of towing. I'm an Engineer as well, and the way I see it, the 3.92 is only helpful at speeds under 24mph. Anyone claiming that the 3.21 struggles at highway speeds is full of ****, even on inclines and declines. So long as you keep it above 24MPH, you won't feel any difference between the two, except the 3.21 will be 1 gear lower. Under 24MPH, there will be some extra strain on the engine, but I trust the 480ftlbs of torque from the EcoDiesel will be adequate.
The 3.21 takes away the super-low starting gear, but it gives you a super-high cruising gear that should sit comfortably at 70-80mph. It'll be slightly quieter and will return an extra ~2mpg. You're basically getting an extra gear, so long as you're comfortable with a slightly slower launch.
As far as gear hunting....every 8-speed FCA vehicle I've ever driven, including the Hemi 3.92 has been a gear-hunting mess, IMO. In fact, a Grand Cherokee I once borrowed was so terrible in the mountains, by the time the transmission settled on a climbing/descending gear, the opportunity had passed. It's going to take a lot of time for me to train my right foot to get the truck into the correct gear, but I'm hoping that I don't have a lot of 7-8 and 8-7 shifts in cruise control.
I'll ask real quick, does the 1500 allow you to set a maximum gear? If I'm climbing a steep mountain road, can I keep the transmission from shifting past a certain gear? Most vehicles allow this, but I'm not familiar with the 5th gen.
Also, is there a "Tiptronic" shift kit that would allow me to override the transmission's controller? Basically, make the 1500 into a manumatic in order to prevent gear hunting.
It's a little more than 500 lbs.If it really matters that your truck can only tow 9500 pounds instead of 10,000 this is the wrong truck for you regardless of the rear axle.
@Johnny h I could be wrong in my understanding of eTorque or maybe they changed how it works, but isn’t that extra grunt from the electrics only during the first half rotation of the tire? I’d love if it gave more. My 4xe wrangler is an absolute rocket off the line with the electric motor and turbo engine working together.
For the most popular configuration, the difference is 8,110 lbs vs 11,210 lbs.
You're spot-on with that. The electric power is only applied for the first half wheel rotation.@Johnny h I could be wrong in my understanding of eTorque or maybe they changed how it works, but isn’t that extra grunt from the electrics only during the first half rotation of the tire? I’d love if it gave more. My 4xe wrangler is an absolute rocket off the line with the electric motor and turbo engine working together.
Of course, but that's because they're definitely above the GVWR of their truck.Fair enough. But I’m still gonna shake my head at guys towing 11,000 pound 36 foot 5th wheels with a 1500.
