MannymanX
5thGenRams Supporter
Most of the other devices are not like that. this one is probably defective. I mean... You can try....Read post 750
How do you test its not going into sleep mode(other than battery going dead) and how days does of truck sitting before going dead?Mine worked fine for about 6-7 months. Now it won't go to sleep and drains the battery constantly. Tested this yesterday and it is still doing it. Unplugged it and put it in the glove box... sucks because I really liked the auto mirror fold, being able to input addresses into the Nav, and being able to leave my 360 cameras on without them timing out.
I think there is a conflict between the Tazer and the new updated software for the truck which doesn't let the Tazer go to sleep anymore. Maybe Z Automotive will come up with a fix in a 18.0.4 version.
Leave it hanging and look for the little red light by the usb port. It should shutoff after a couple minutes when the dash goes dark. When mine went dead, it happened in less than 9 hours. 0 volts from battery.How do you test its not going into sleep mode(other than battery going dead) and how days does of truck sitting before going dead?
I got mine plugged in and configured. No problems just had to do it a couple of times to figure it out. I wish the instructions were written better tho. or I'm just an idiot
When changing tire sizes with the Tazer DT, does it also correct shift points like the Rough Country Module? Does it disable the self parking features like the Rough Country?
	I was wondering the same thing. Just taking a guess but I bet by calibrating the speed the shift points are corrected due to the ECM receiving the correct speed.bNot that its a separate step. Plausible?When changing tire sizes with the Tazer DT, does it also correct shift points like the Rough Country Module? Does it disable the self parking features like the Rough Country?
Sent from my SM-N976V using Tapatalk
Does anyone know what the "Set LED CMHSL: This setting is to configure the vehicle for LED 3rd brake light." does really? I have a limited, and the 3rd brake light and 2 cargo bulbs were not LED. I used the HID KIT PRO bulb kit to swap them over. I am not sure why there would need to be a setting in Tazer for this?
One other thing I didn't see addressed on here. Can you use a Diablo Sport tuner w/ unlocked PCM as well as the Tazer? I already have the Diablo module plugged into the SGW location. Is there some adapter that allows you to plug in 2 things, or is that just not possible?
You can use both. That's why the tazer require you to activate the cruise control.Yeah, I understand that. I don't have anything plugged into my OBD port. In order to use the Diablo unlocked PCM, they have a module that has to plug into the SGW location, which is where the Tazer plugs in. I text the Zauto guy, so we will see if I get a response.
