Successful Upgrade - 2022 8.4 Uconnect 5 with NAV to 12 Uconnect 5 [with pictures]
@rbusbee thank you for this thread. @Jimmy07 thank you for the harnesses. Great work on those. 1st mod on my 22 BH. Went from 8.4 UConnect 5 non-nav to 12” UConnect 5 Nav. Everything worked as the thread did.
Waiting on screen n module to get here I may pick your brain on some things!!
I have a 2022 ram 1500 bighorn. I bought it from an auction site after the radio and hvac controls had been stolen out of it so I don’t know if it ever had navigation or not but I know it had the 8.4” screen. I bought all the parts I needed to upgrade to the 12” radio from mopar. 68526597ac 68504644af and 6uv481x7ab. It fits in good but there’s three spots on the radio I don’t have wires for. I circled them in red. I’m not sure if I need them or if that’s for an option I don’t have. I also have one wire that doesn’t have a spot to go in that is very very close to fitting in the spot on the back of the screen but doesn’t make it. I hooked everything together that I have and none of the buttons work and the screen won’t come on. The sound of Sirius channel one plays over the speakers which can’t be turned off. I have the gateway bypass and alphaobd and I changed the center stack setting from enabled to disabled. Is there anything you guys have in mind that can help me figure this out? I appreciate any help you can give me. IMG_1417.jpegIMG_1419.jpeg
I have a 2022 ram 1500 bighorn. I bought it from an auction site after the radio and hvac controls had been stolen out of it so I don’t know if it ever had navigation or not but I know it had the 8.4” screen. I bought all the parts I needed to upgrade to the 12” radio from mopar. 68526597ac 68504644af and 6uv481x7ab. It fits in good but there’s three spots on the radio I don’t have wires for. I circled them in red. I’m not sure if I need them or if that’s for an option I don’t have. I also have one wire that doesn’t have a spot to go in that is very very close to fitting in the spot on the back of the screen but doesn’t make it. I hooked everything together that I have and none of the buttons work and the screen won’t come on. The sound of Sirius channel one plays over the speakers which can’t be turned off. I have the gateway bypass and alphaobd and I changed the center stack setting from enabled to disabled. Is there anything you guys have in mind that can help me figure this out? I appreciate any help you can give me. View attachment 196660View attachment 196661
The wide black plug is Ethernet and not used, the double green is WiFi/bluetooth, also not needed. The square black plug needs to be connected to the screen whether you make or buy an adapter for it.
When you say the black plug needs to connect to the screen im guessing you mean the wire in the picture I took that looks like it should be in the screen? Do you know what adapter I would need? Thanks
I almost forgot to include the (very limited) information I was able to find regarding 12in bezels. There's probably a better resource on this forum. I collected this through a secondary parts dealer's website. So, I cannot vouch for it's accuracy.
Part No.ScreenColorBadgeInterior Accents
6EZ155X9AE
12.0​
BlackBlack
6UV463XLAB
12.0​
6UV481X7AB
12.0​
BlackSport/Rebel
6UV483XRAB
12.0​
Black/RedSport/Rebel
6WQ606X9AA
12.0​
Black
6WQ641A1AA
12.0​
BlackCarbon Fiber
7BT351AHAA
12.0​
BlackBig Horn/Lone StarBlack Olive Ash Burl
7BU482N1AA
12.0​
Mountain Brown/Lt. Frost Beige
7CY161XDAA
12.0​
Black/TRX RedSerialized Dash Plaque
7DW912X7AA
12.0​
BlackGT Interior Theme
7JJ142A1AA
12.0​
Carbon FiberOrange Seat Insert?
UPDATE: You can just order the replacement accent piece. Mopar calls it the "Applique."
68469683AA looks like this:
Closeup of design:
68489746AA is the matte black:
68469682AA (Metal Plate):
68576214A (wood grain):
If anybody has any corrections for the part numbers, let know. I am certain the first two are correct (I ordered both). My truck came with the matte black, and the upgrade I got on ebay came with the glossy, 68469683AA. The matte black, 68469683AA, is actually the cheapest, but I like it better, and it matches the rest of my interior.
Honestly, I cannot imagine why anyone would do this. I consider it a downgrade. I love having simple knobs and buttons to control most things. I have am on my second (2020) and had a 2015 prior. Both with the 8.4, and I would buy a 2025 if I could get the hemi, and an 8.4 Uconnect. My friend has the larger screen, when the sun shines in, he usually can't see a damn thing!
Ok I got all the right parts and installed everything correctly with all the new wires. I change the two settings in alpha obd and have let it sit for two hours. So the radio comes on and I can use the two knobs to control the volume and tuner. The hazard light works and the rear defrost button works. All the other climate control buttons and the screen do not work at all. Any suggestions?? Thanks guys
When I first did mine the screen didn’t come on either. Jimmy07 had me check continuity on the ldvs cable. There is a difference between uc4 and uc5 cables and they plug in, but are not interchangeable. I could not find a uc5 cable, so I cut mine and soldered it back together in the correct configuration.
This is the one I bought 2019-2023 Ram Truck UAX UAV LVDS Display Harness
That shows from 19 up, so might be for uc4. Try checking for continuity like the pic above. If the pins are out of order it won’t work.
Thank you for your help. I changed that cord out with another one I had and the screen comes on now. Unfortunately none of the hvac controls are working. The buttons on the side or the buttons on the screen
Is it possible your truck has single zone climate and the screen/bezel is for dual zone?
I’m not sure actually I bought the truck from an auction site after it had been stolen and the entire radio and controls were stolen so I never knew what was in there.
Would any of the controls work if that were the case?
Someone else posted this on another thread: For the non responsive hvac bezel and stuck-on defrost, I needed to enable Dual zone temperature control with alfaobd, even though my truck does not have that functionality
Thank you so much I tried that and everything seems to be working
Anyone on here have your old part numbers handy for uconnect 5 w/ nav?
I am wanting to switch from 8.4 no nav to 8.4 with nav for the hd fm signal. Non-nav are not hd radio, highly noticeable with good aftermarket system. Looking for the receiver and disassociated display part numbers. I don’t want the bigger screen if possible. Mine is 21 Bighorn w/ manual a/c and heated seats/steering (added).
I am also very thankful for the details on the swap, as I have just purchased a 12.1 (found a 68526609AB made Oct 21, 2021) to replace my 8.4 on my 2022 with UC 5 and nav. From what I read, the one I bought is directly replaced by 68526597AC in 2022-23 but should fit my 2022 RAM Big Horn and is the right color bezel. I don't believe there was any changes between 21 and 22-23 in regards to the screen and it's functions. Please correct me if I'm wrong.
I just need to examine the ALFAobd and OBD2 reader part of the instillation more closely. I have an OBD2 reader already and it's using DashCmd app on my phone. It's pretty comprehensive as far as engine management readings, engine codes, etc. But not sure how I would use this for what it's needed. Are there better instructions on Alfaobd and how to use it. The site linked is not user-friendly. :-( Very confusing. I can do the basic unplug and replug install part of this. Just didn't know if better to go to somewhere like American Radio to get the last aspect done- changing the readings to have screen function for A/C, etc.
I can confirm that part number works in my 2022 big horn. I originally had the 8.4 with nav. I don’t have the radio trim yet because I thought the eBay listing came with it… but I decided to hook everything up anyway. Also pictured. The JScan settings I had to change to get the radio to power on. Took about 3 minutes for the screen to turn on. All the buttons worked instantly
I connected my wife's phone and had the same issue. So, it has to be the radio. When I changed it out, I needed 7 M5-0.8x12mm bolts. The only ones my local Lowes had were iron carriage bolts. I'm wondering if the iron is interfering with the signal. It's a long shot, but I've ordered the actual replacement screws from mopar. We'll see.
I do not. The one I ordered came with the mat. Check out:
They usually have more info about the parts than store.mopar.com. Looks like maybe 6MB16TX7AA
Thanks SO MUCH for that link. Every site I've been to has nothing but useless information and no actual pictures, until this place!
