what size is the hk sub?yup but only on the alpine, the HK uses a single voice coil sub
10what size is the hk sub?
Foxacoustics.com has a few.Where can I get a subwoofer box, to put a 10” Kicker Comp R sub? I can’t find any after market box’s that will fit perfectly under my back seat. I looked everywhere online that I can think of..... I have a Big Horn - Crew Cab
What about the ohm rating and number of voice coils?
That Alpine is going to be tough to replace. Nobody makes those. Will have to go with a dual 2 ohm voice coil sub and lose a channel.the alpine is a triple 2 ohm voice coil and i believe the hk sub is a single 2 ohm voice coil.
Good point to bring up!!! One thing i wasn't ready for is how intricate of a process removing front door trim is. Anyone reading this post do yourself a favor and download the attached pdf file below. (you'll be glad you did, I know i was)One thing that happened on my panels.
Right below the arm rest where the plastic meets the leather rest is where the lower portion of the plastic panel is joined to the upper, they use a plastic melt rivet to joint them together and its brittle and will tear loose. Try popping the pins that hold the upper panel first otherwise there is good chance the 2 panels will separate, 3 of mine split right there I just put them back together with 2 part epoxy
**Polarity Phase for the Front and rear door speakers are reversed. the pdf attached below shows the wiring blueprint for stock ampI changed the polarity on everything except today the front left dash. Everything else was the wrong way. Still have to change out my front doors. Everything sounded better once it was all in the correct phase.
I saw some people had issues with these. How hard are they to install?
They fit, you'll have to trim the edge of the tab if you want it to fit perfect, but even without that they will still drop in the hole. Order them elsewhere, you just won't get the free metra harnesses. You will have to order those seperate. Ebay and Amazon have plenty of the GX302s.Seems they don’t make the 302’s anymore? Also, crutchfield says they don’t fit? Any advice?
thats awesome . do you know where I could find the same diagram for the hk sub ?**Polarity Phase for the Front and rear door speakers are reversed. the pdf attached below shows the wiring blueprint for stock amp
You won't find anything like that for the HK. I made that diagram for the alpine system after tracing all the wires and verifying polarities. Both of mvaldezsthats awesome . do you know where I could find the same diagram for the hk sub ?
You won't find anything quite like what he posted. I made that schematic for the alpine after tracing all the wiring and verifying polarity. It's the factory schematic that I edited. There is a schematic for the HK system floating around but no one has verified if its correct to my knowledgethats awesome . do you know where I could find the same diagram for the hk sub ?
Yes Do Do this! Such A Painstaking process!Good point to bring up!!! One thing i wasn't ready for is how intricate of a process removing front door trim is. Anyone reading this post do yourself a favor and download the attached pdf file below. (you'll be glad you did, I know i was)
