DennisY
- Sep 23, 2018
Couple questions on this....you said you ran from the factory sub, i'm assuming you disconnected the factory sub and used those wires as a feed to your subs? Secondly, what ohm are the subs your using? I wonder...just wonder...if this setup you're doing (for the moment) is too much on the factory amp? Just things I am thinking of...lol
Yes, I used the wires from the factory sub to feed the new subs. The new ones are 4 ohm subs. They are in parallel right now so thus they present a 2 ohm load. I don't know the specs on the factory amp but during testing this afternoon, all was well. I do plan to put in my aftermarket amp though.
