dannydyn
Oops lol
Could you link your build sheet? You may have a unicorn, as the Ram website lists E-Torque Rebels coming with 23-gallon tanksI have eTorque and a 26-gal. tank.
https://www.ramtrucks.com/build.ram...WBT,G7,XHC,DMH,Z6D,UAA,AHC,XR,PR4-QXJ,27W,APDQuad cab is the reason I believe. Crew cab Rebels with eTorque will be 23.
Quad cab 5.7 etorque, with or without tow group, is listed on the website as 23 gallons standard. Maybe early builds had 26, then they switched to 23?
FWIW, mine was purchased 4-weeks ago so maybe something changed with newer trucks.
My 2019 Ram Rebel E-Torque Crew Cab manufacturer sheet states 5 Additional gallons. I ran the truck until the computer displayed 40 miles until empty. Then I filled it up with exactly 27 gallons, which makes me think they took the 23 gallon added 5 = 28 Gallons which is not even an option.... the other side of this would be taking your average MPG your computer is displaying and dividing 13 (MPG) into 40 (until empty) that would make about 3 gallons left in the tank, 27 + 3 = 30, I doubt that i have the 33 gallon option but at this point I don't really know.
From what I recall some Canadien Rebel with eTorque had 26 gallons standard or as an option.
I have never seen a Canadian Rebel with a ETorque, was never a option.
I have 26 gallon. It's listed on my build sheet I downloaded. Plus, my wife helped me get to near zero gallons, and I put over 23 gallons back in it.What is confusing is what would justify the "upgrade" from 23 to 26? I have every option on the Rebel except for the air suspension and 33 gallon tank effectively. What would you have to do to get the 26? I am thinking maybe no one has 26 in the Rebel, only 23 or 33. That would make much more sense to me, but I have at least 3 official documents from Ram that say the Rebel has a 26-gallon tank standard. I confirmed it in multiple places before my actual fill-ups made me wonder.
I have the 5.7L w/etorque crew cab. I am finding conflicting info as to the fuel tank size. Sometimes it says 23 gallons, but more often it says 26 gallons. I am about to go all the way to the bottom with a fuel can in the truck to figure it out myself, but I would prefer not to have to do this. I think the etorque 5.7L gets 26 gallons standard.
On my last fill-up, I went all the way until the distance to empty said 40 miles, but I was only able to put in 17 gallons. Even with a 23-gallon tank, this estimate was way off (should be more like 90 miles left) and it's even farther off with a 26-gallon tank. I know some Ram/Dodge products are off in this regard and it's common.
Thanks.
