z0n3
- Jun 16, 2019
Third issue is the next one I’m targeting for them to fix. I have had the rear brake moan and it was solved with a simple bracket. My rears have developed a slight squeak when applying the brakes. Dealership is going to add some adapter, and new calipers. Brake issues on these trucks are never ending. Atleast mine. They perform well but can’t keep quiet.There are two different (three actually) with brakes on these trucks. I’ve experienced all three.
- Front brake squeal
- Rear brake moan when wet
- Brake chirp
First issue, squeal when light braking, was fixed for me right away. Dealer replaced with redesigned front brake pads and swapped rotors.
Second issue is not a big deal to me. It just does this for a second or two after washing the truck, and goes away after applying the brakes before I’m out of the driveway.
Third is the chirp, which was fixed for me once they replaced calipers. This chirp literally sounded like a cricket, and would make this noise with engine on or off, anytime I would get in or out of the truck, or go over a speed bump (not when braking).
No issues for several months after the dealer fix, until it cam back briefly last March or April, but then went away and has been quiet since. So for all intents and purposes, fixed.
Neurobit
