‘19ramlveryeha
- Jun 9, 2019
Imagine this extreme example. You only push the pedal 1 inch forward, there's a 10 second delay, then the truck goes from idle to wide open throttle.
I watched the SprintBooster video and was immediately sold on the 1:1 throttle response. But I don't think that's the issue with these trucks. There is a delay from the time you move the pedal any direction and the truck reacts - it's about a 1/4 second. I didn't buy the SB but got the Pedal Commander instead, and it did not change this behavior. I don't think any of these electronic throttle programmers will fix that complaint.
What these throttle programmers will do is change how much oomph you get across your pedal travel. Want to push the pedal 1 inch and go WOT? There's probably a setting for that, and then obviously anything in between. So you can tune the pedal sensitivity to your liking, but not the responsiveness of changes in pedal position.
Totally right about the delay. I’ve got the pc and you can tell there is a delay except for eco and that’s only because it feels like a gradual smooth acceleration.
