Icecoldak
Maybe they will get the 2021 RAM right and no bad Vibes!
Has this been resolved yet?
I test drove a 2019 Laramie with a February 18 build date and at higher speeds I experienced the same vibration as so many others have described here. Loved the truck otherwise but didn’t pull the trigger.Does anybody with the 6 Cylinder gas or ecodiesel have the issue
From what I understand the active tuned mass modules are only on the Hemi
If you feel a shake on a test drive definitely dont buy that truck. Most have not been able to solve the issue. I'll most likely be going through a lemon law case for mine here soon.
I wouldn't let WalMart touch my $20k Ford Transit Connect work van.
I second the road force balance. If done correctly, it can fix the/MY issue. (Read my posts) They will likely need to replace tires in order to get the best results from the road force balance. My truck is still riding smooth. It was like getting a new truck again. Now I just wish my transmission would have smoother downshifts when coming to a stop...Wheel Balancing comes in various techniques.
Always have your wheels "ROAD FORCE" Balanced.
Some people don't even know what it is.
For reference sake, what tires/wheels are you riding on now?I second the road force balance. If done correctly, it can fix the/MY issue. (Read my posts) They will likely need to replace tires in order to get the best results from the road force balance. My truck is still riding smooth. It was like getting a new truck again. Now I just wish my transmission would have smoother downshifts when coming to a stop...
I would just recommend that if you are considering a purchase of the new Ram; you should do multiple test drives. If it doesn't vibrate then I think you should be good. If you do notice the slightest vibration then don't buy it. Don't listen to them when they say "its just flat spots in the tires". There are plenty of these trucks to choose from.
Same wheels (base Laramie 18") with Goodyear SR-A tires. They replaced all of the stock Goodyear Fortitude's with the SR-A. Not a fan of them, but had no choice because it was covered under warranty. They then had to replace 2 additional SR-A tires in order to get a good RF balance.For reference sake, what tires/wheels are you riding on now?
Hi everyone,
Let us know if you decide to have your dealers look into this. Just send us a private message so we can assist in making sure that this gets addressed.
Lydia
Ram Social Care Specialist
I need help on my 2019 RAM with this vibration issue. It’s is terrible at 40mph when coasting.Hi everyone,
Lydia
I noticed this with the spare too. I have removed the spare and my vibration was mildly reduced, difficult to actually tell. Problem is the underlying cause of the vibration still exists, the spare may amplify but is not the cause. Rotating mass is the root cause most of the time but not always, that's what makes solving these issues next to impossible...I grabbed the spare tire...and it shook. It felt exactly like the vibration I feel in the truck. Now I haven't had a moment to get back to my truck to test this by removing the spare but let's hypothesize for a moment that when we get up to a certain speed or frequency the vibration runs through the vehicle and finds itself in our spare and shakes it back and forth while were driving....
My truck is vibrating badly. I drive 26 miles to work. By the time I get out my hand is slightly numb like after using a jackhammer. I'm so frustrated. It's even in the pedals. I'm embarrassed to tell my wife I own a piece of junk.
I litteraly researched this purchase for 9 months nonstop. I don't have 5k miles on it.
I don't know what to do.
