boogielander
- Jun 29, 2022
oh now that makes sense!The trans was with the pan/filter. So several hundred more than a drain and pour.
The squeeze bags are a game changerFor you and to clear up the cost of the transfer case fluid, I used AMSOIL for all of it. Mobil 1 synthetic for oil and filter, but that's my normal brand. Transfer case could have been cheaper, but I bought the squeeze packs since it goes from a 30 minute job to a 5 minute job. More like $100 for everything instead of the original 200. I hadn't looked up the order when I said that number.
80W-90 Synthetic Gear for front diff - $10
75W-140 Severe Gear for rear diff - $15
OE Multi Vehicle Synthetic ATF for transfer case - $35
Just spent a week switching back and forth between 2WD and 4Hi while on ice/snow in Memphis. Several long drives at 30-60mph in 4Hi as well as a lot of switching back and forth at speeds below 40mph. No clunking, switching issues, etc.
^^^This60,000 per zf’s website
Damn, you mean the $200 quoted from someone else is wrong?! *GASPThe PPE aluminum pan which cost about the same as the Mopar pan and the zf fluid costs me about $600 to do it myself. The dealer wanted $1200
60k is usually the interval we recommend for all platforms regardless of make and model (other than Honda CVTs... those we recommend at 30k because we've seen too many Honda CVT go to heaven following the book's recommended interval)Curious what type of intervals are you guys going with for both the differentials and trans fluid service. Im sure Ram thinks the ZF trans fluid should last forever or at least till 100k but let’s be realistic lol.
Yep. I did this at 53K.60k is usually the interval we recommend for all platforms regardless of make and model (other than Honda CVTs... those we recommend at 30k because we've seen too many Honda CVT go to heaven following the book's recommended interval)
If you offroad a lot/ hard or you tow, you'd want to do it earlier than 60k. For mine I'll probably do it at around 40-50k just because my truck plays a lot off pavement compared to what the factory standard.
thought I would share how much the dealer here in crawfordsville indiana will charge for a transmission oil and filter swap. 750 to 800. It was kind of a funny conversation. The guy said its not warranted on my truck. I said that maybe so by your standards but the manufacturer of the transmission says otherwise. I may just do this myself. How many have gotten the pan where you can change filter without pulling the pan? and how do you like it
If you got a $199 trans service i believe you might want to recheck the work.I own a auto repair shop. The Correct ATF costs $27 per qt @ 6-7 needed. The correct transfer case fluid is $45 per qt @ 1.8 qts. The filter alone is about $300 it is 1 piece with the pan.Oil Change = $89.95
Front Diff Fluid Change = $119.95
Rear Diff Fluid Change = $119.95
Transmission Fluid Change = $199.95 (a transmission flush with the change adds about $25)
The internet told him, so it must be right and he doesn't want to believe otherwise since the internet told himIf you got a $199 trans service i believe you might want to recheck the work.I own a auto repair shop. The Correct ATF costs $27 per qt @ 6-7 needed. The correct transfer case fluid is $45 per qt @ 1.8 qts. The filter alone is about $300 it is 1 piece with the pan.
If you actually own an auto repair shop you should know the recommended ATF can be purchased for less than $8 per quart.
The internet told him, so it must be right and he doesn't want to believe otherwise since the internet told him![]()
Because all the internet social media arguments against the posted price seem to rely on false information like $27 dollar per quart transmission fluid when that fluid can be purchased for less than $8 per quart.
