dreinert
Perfect, thanks for the support Vince!
Dallas
Dallas
There is someone in the Discord group that is working to see if it is possible, but don't know where he is with it yet.OK, I’m not quite there yet, but is there any reason the comma stuff won’t work on a 2021 2500 with ACC and Lane Keep Assist? Kevin.
I have tried a few of the previous links to try to join the Comma Discord group (from my iPad) but so far no luck. Any easy way to do this?There is someone in the Discord group that is working to see if it is possible, but don't know where he is with it yet.
Actually, om the 1500, it now steers to zero, so is useful in stop and go traffic and in town. It is not the official release, but a 1500 bet fork.Just wanted to revive this post as it appears comma 3 is officially supported on the webpage. Anyone whos been using this have an update? Still only useful on highways/above 31mph?
You will need to join DiscordWould you mind linking to the fork or DM’ing it to me?
Just got a 1500 this past weekend. Have used open pilot in my civic and going to be installing the new comma3 tomorrow.
Discord - Group Chat That’s All Fun & Games
Discord is great for playing games and chilling with friends, or even building a worldwide community. Customize your own space to talk, play, and hang out.discord.gg
Got my Comma3 installed yesterday. Agree that installation was easy. Make sure you pull the large plastic shroud around the mirror off first, then you can reach in and pop the tabs for the smaller plastic piece in the center to remove the whole thing from the mirror.
The included Ethernet cable is long enough but just barely, barely an inch to spare. I routed mine along headliner up top then down left A pillar under the rubber molding then across to OBD.
Don’t have as much driving experience with it yet as above but have used Comma2 in my civic for years so can vouch for openpilot being a game changer.
There is a side Airbag in the "A" pillar. It is best to pull the trim of the A pillar then pull the weatherstripping away from the Door Jamb next to the Dash to Run that Cable.
Malodave
Malodave
I popped the big trim piece off first, and even popped the mirror off its stalk. I still could not reach behind the trim to get that small plastic piece out.
I did not do all that. I loosened (but not removed) the bolts holding the grab handle on. I did not pull any trim/moulding/weatherstripping off of anything. The cable tucked in behind easily and I can't see it.
I ran mine starting from the OBD port and going up. I had plenty of length to spare when I got to the top to plug it into the black box. @chronorp, maybe you routed the cable under the bottom edge of the lower dash, instead of through it from the side? If you run it through the side, there should be a few more inches of slack for you.
