Hrspwr88
- Dec 2, 2019
I believe this is a simple software issue rather than a battery issue.
My fail log shows low battery voltage is the reason for the no start. But when I start the truck manually it fires up. To me this tells me the system check for battery voltage is too conservative and needs to be adjusted. Until then this problem will happen.
As mentioned prior, I am convinced this is a remote start software issue. The battery threshold for a start vs no start needs to be updated. Until then this issue will continue. The dealer changed my battery too but even after every failed remote start my truck will manually start fine. So the battery really isn't the issue.
Let's see...
