Idahoktm
Well, add me to the list. 2021 with about 50k. Have a slight dribble upper left and right but no visable crack. 3rd brake light has the 682298380AE as the factory installed. Might install the "AH" with the big fatter gasket... I'm assuming I'm out of pocket considering I'm outside the warranty period. Add this to another RAM expense that RAM doesn't cover for me.
I'll probably just hit it with the flowable silicone but found this video about "Poly Foam Caulk Saver" used in the same location on a Ford. Seems cleaner and easier to refresh later when needed. Anyone use this for this purpose?
That would be worth a try before using Permatex, IMO.
