No problem. On your wire you are getting from the donor vehicle is it the entire wiring harness under the carpet? If not I can find a tread where I saw someone who didn’t have the connectors in the back make a harness themselves to make the back seats work.
It's the entire floor and dashboard harness; but I would appreciate seeing the thread about the built harness.
I did see a post on here about this swap requiring 4 wires be added. As you can see below, at least in my case, that poster had no idea what they were talking about.
So far, reverse engineering the harness, and with the connector info you gave me; I going to need to run:
6 wires between Drivers and Pass yellow plugs; for Driver's heat.
3 PN/YL FUSED IGNITION from Pass Yellow to that junction block (think it's drivers footwell area).
2 CAN IHS from Pass Yellow to CAN junction block (think it's drivers footwell area)
2 wires from Pass yellow to clock spring (for heated wheel)
Others I haven't identified yet.
The donor Driver's seat included the Memory Module. Right now, I'm trying to avoid using it. Several reasons. I really don't care about the Memory function; I didn't get the door Memory switch from the donor truck; and most importantly-it requires 26 wires. I'm planning to swap the heated seat pads and vent fan from the donor Driver's seat to my seat and leave the power function as is (no memory) on my seat. Pretty sure Memory controls only the Driver's seat.
If I succeed with this (not too confident-although I've added power/heated seats to 2 previous vehicles), I'll share all the information on here.
