_northram
- Oct 21, 2020
Thanks man, wheels are a 20x9 +1 offset and 5 backspacing.Looks awesome. What backspacing does your wheels have?
Post some pics when you get it onJust pulled the trigger for the readylift kit. Plan on going with Bilsteins in lieu of preload spacer with the ORP springs.
I noticed the places that have the kit for under $700 has dropped. Only Amazon and Walmart now. There were about 5 different sellers last week.
Yes, please share. I think I am going to go with just the 2“ ReadyLift Control Arms with the top hat spacer and some adjustable Bilsteins and maybe set them to lift an additional .5-1”. Then figure out what size spacer I need for the rear.Just pulled the trigger for the readylift kit. Plan on going with Bilsteins in lieu of preload spacer with the ORP springs.
They are the same. Why use the top hat when you can just lift with the 5100s? If you want even more by adding top hat.... then you’ll likely need rear spacers.Thanks for reply.
There are two kits.
69-1921 ‘2” level’ for UCA and top hat
69-1935 ‘3.5” lift’ for UCA, top hat, preload spacer and rear spacers.
I’m just curious if the top hats from both kits are identical as I’m planning on lifting with 5100s and top spacer and UCA. If so, I don’t need rear spacer or preload and can save ~$200 if they’re the same.
We’re you able to confirm the top hats were identical for both kits. I called them with the idea of just buying the kit with the top hat and then setting the 5100 and the person only said “we can’t comment on if that will work on not”. I asked how preloading with spacer was different than preloading with 5100 and just got some rambling about it “not being tested”.Just pulled the trigger for the readylift kit. Plan on going with Bilsteins in lieu of preload spacer with the ORP springs.
By using the top hat you could get to 3.5 which isn’t possible just on the bilsteins right?They are the same. Why use the top hat when you can just lift with the 5100s? If you want even more by adding top hat.... then you’ll likely need rear spacers.
Sure, you could add a top hat spacer to the Bilsteins and put them on setting #5 to get to 3.5”. Then, you’d probably want to add control arms as well. As mentioned, you can only get an additional 2” with the Bilsteins alone.By using the top hat you could get to 3.5 which isn’t possible just on the bilsteins right?
I created a thread in the modification forum but here’s some pics.
This may be a dumb question, but why is people buying and paying for the readylift kits and know they can’t use the preload spacer and buying the bilsteins and swapping them out when technically ur only getting a 2” lift not using the preload when u can pay just a little more for mopar 2” lift that has control arms and fox upgraded shocks which in my opinion is a better shock than bilstein, nothing against bilstein they’re a great shock too, I just think the foxs ride better, and u still maintain your warranty?
I've seen the Readylift kit for like $600ish bucks. I thought the Mopar kit was $1,500?
No, the one I seen online through Mopar was like $1200 retailI've seen the Readylift kit for like $600ish bucks. I thought the Mopar kit was $1,500?
New to this forum just got my 21 rebel thinking to go with the readylift 3.5 a lot of mixed reviews just wanna know from you how it’s holding up for you until now and did you use the preload spacer or not thanks.Mine rides great on and off road . I originally put on anza 20/9 with 34/11.5 BFG tires but I hated the look and the ride. I switched the tires for GY wrangler duratracs 35/12.5 and love it!!!
