SurfRebel20
- Oct 3, 2020
The 6112s only lift the rebels 2 inches max. So I added half in spacer. I'm 2.5 inches above stock rebel height or 3.5 above a non rebel. My angles are good it's almost been a year no issues. My front end is 41.5 inches from ground to bottom of fenderThanks for the reply, thats what I was thinking I notice lots of people are using the Zone for the 2019 -2021. Dont know why Zone would not recommend for the 5th Gen. Looking at your set up I see you are using spacer in the front, how many inches is it lifted in the front if you dont mind me asking. 1 inch lift factory, if you are using the max setting on the 6112 thats 2 1/2 and then the spacer = what? wondering the angle on that control arm ball joint.
The 6112s only raise the tebThanks for the reply, thats what I was thinking I notice lots of people are using the Zone for the 2019 -2021. Dont know why Zone would not recommend for the 5th Gen. Looking at your set up I see you are using spacer in the front, how many inches is it lifted in the front if you dont mind me asking. 1 inch lift factory, if you are using the max setting on the 6112 thats 2 1/2 and then the spacer = what? wondering the angle on that control arm ball joint.
