Ram Rebel 2019 - Bilstein 6112 and 5160..Do I need to change/upgrade the UCA?
Thanks for the reply, thats what I was thinking I notice lots of people are using the Zone for the 2019 -2021. Dont know why Zone would not recommend for the 5th Gen. Looking at your set up I see you are using spacer in the front, how many inches is it lifted in the front if you dont mind me asking. 1 inch lift factory, if you are using the max setting on the 6112 thats 2 1/2 and then the spacer = what? wondering the angle on that control arm ball joint.
The 6112s only lift the rebels 2 inches max. So I added half in spacer. I'm 2.5 inches above stock rebel height or 3.5 above a non rebel. My angles are good it's almost been a year no issues. My front end is 41.5 inches from ground to bottom of fender
The 6112s only raise the teb
Thanks so much for the info, Just placed the order for the UCA. Will put some pics up when everything is installed.
Got the 6112 (clip 8) and 5160's installed (along with rear spring and UCA). I use this to tow so wanted half - 1" of rake still. Put the new wheels and tires. 295/70r18 fit. Had to remove small front mudflap and bend back metal bracket, then put the factory mud guard back on.
Super happy so far with the setup.
Off subject, how do you like those Yokohama Geolanders?
How about 4wd differential?....no issues?
