I am the type of person that typically see all 3 sides to the coin/situation....my side, their side, and the truth from both sides.
While I see riccnick's points are valid and is a "single" test/check of what is deemed normal for the a/c parameters. I do wonder if that dirty filter plays a part on it along with all the other variables (location, amb temp, pano, tinted windows/etc...). I appreciate you documenting it from start to finish---helps us DIYers.
I also see the valid points with coming up with a fix (jhill+others) if manufacturer has not (yet); or will not as in other cases of problems with mass vehicles but don't get the greenlight for
Service Bulletin FIX. <---that should get to the point of exactly what part/etc is faulty/needing repaired---until the exact problem; alternatives can ease the sweat.
Bottom line is reverse the shoes and then see what actions "YOU" (everyone of us) would be doing in that situation??? Often, people as a whole change their tunes when the "heat" is directly on them vs looking at situation from a safe distance. These are broad statements not directed at anyone....And I must say this has been pleasant "conversation/aka debate/discussion etc" compared to other forums in my past too.
I personally have tested (not all in compliance to proper procedures) my vents with temp-gauge and after my "equipment fix" (you will see via pic), have to say I am still torn with the output of my A/C. Personally I will test it several more times. Of course different times of the day and other variables play a part. Bottom line is my butt-o-meter says it can be better. Thus I can appreciate the temp/fix option (thanks again Jhill+ others) and may have to resort to it come the HOTTER MONTHS down here in SouthWest Florida!!!
So, I appreciate all three sides as there is truth on both sides, and this deserves a fix in my opinion.
Even if all the vehicles are tested and are in compliance per Manufacturer's specs (who made the parameters???), and depending on the percentage of complaints of those suffering (insert Bean Counters here) depending on the bottom line of the "cost" of this and future sales....changes can/should be made. Unfortunately it boils down to money as we all know. How squeaky is this wheel(AC issue)???!!!!!!
Yes, I went and purchased a new gauge after my very first readings!!!!
Make sure your equipment is working properly:
Here's what it is like right now in Cape Coral/Fort Myers Fl area:
88° | 73°
94 F
FEELS LIKE 115°
