Thanks, this info helps a lot, and yes, adding to your signature is great, thank you.
I haven't been checking in daily because i just came over here and discovered ramchat today, where they said my status had "changed recently" from the "ready to build" (assume that was "D") I got from the dealer April 12 to "parts received (assume "D1") i got from RamChat today.
When you say you checked in daily after D1 - was that with Carl or RamChat? Space4092 seems to say must be with the dealer cause RamChat won't give you the specific details?
And sounds like it was 20 days from D1 to window sticker for you? good luck finishing it out soon!
Yup.... Welcome to the suck!So what you're saying is I'm gonna have a long wait? (I ordered mine 1 week ago)...![]()
Thanks very helpful to have a timeline going into D1!!I got the updates from both RamChat and my salesman, Carl. After I got the POC/VIN, I checked in with RamChat about 1x per week. Then, once it moved from D gathering parts to D1 all parts received and being scheduled, I got an email from Carl. After that I checked in daily - mostly so that I could get a timeline about the build process. I wanted to see exactly how long it spent in D1 before the build started, and then in the other stages, too. I thought adding that info in my signature might give everyone another reference point for how long these builds take. No two are the same though.
When did you get the “parts received” info?
I got a VIN when I went into D status...I am in SKSeems not bad, except for I status = Built not Ok'd, or in other words they damaged something in process and need to fix it.
I'm in Calgary, ordered 3/10, D status 3/25, no change since. Dealer said they will advise when VIN is populated or D1, but check back end of April regardless. Anticipating I won't see my truck until June/July. Meanwhile my 4th gen just started leaking around the water pump (porous aluminum vs. gasket) meaning I just lost $2k in value waiting.![]()
I got some land on Manitoulin Island, need the truck latest May 15, going camping![]()
Has anyone else gotten the RAM Chat response that the vehicle is built but awaiting additional equipment? Curious if this means I am past the chip shortage issue or if they're building them w/o certain stuff and parking until the rest of the parts come in.
Ordered late Feb and this was the first time I've used RAM Chat. Longhorn Limited etorqe V8 with every option except off road, cold weather, and air suspension.
that's awesome, an automatic reminder when the build sheet comes up!!!Update and reminder for those tracking.
I forgot about this, but I input my VIN into https://cryptostickers.net/default a while back and forgot about it .... just got an email that said my VIN tracking info changed - I now have a build sheet!
I checked in 2 days ago, and it still was in the "all parts are gathered and entering build process shortly..." so I supposed that means it's entered build?
*Edit/Update* RamChat states "vehicle has been built and is pending installation of additional equipment" so off to BUG and steps installed I guess.
My order date is 2/23 so just over 8 weeks.
just put in a name, it's just for you to look it upI tried your link, CRYPTOSTICKERS to check on my VIN, but it asks for a Nickname. Anyone know what that means?
From
I got an email that window sticker was found but when I click on the link "Sorry, a windows sticker is unavailable for this VIN".
Anyone else has this?
Congratulations! Looks great!Order 2-26
Showed up at mark dodge yesterday
Thank youCongratulations! Looks great!
