Expat
- Apr 18, 2019
Schaeffer’s Supreme 9000............10,000 mile inervals...........wix premium filter...........46,000 on the clock now
The 5.7 HEMI in HD applications has not gone well, but yeah... In a half-ton, it is easily the best motor and tranny combo money can buy.This is part of why I'm so happy to have a Ram truck. The Engine and transmission.
This 5.7 Hemi has seen life and use in 3/4ton trucks for many many years!
Good tips on the oil life there. This thread has a lot of neat info in it
Update! I started doing 5k intervals, as I feel the MDS kick in much harder after the oil hits the 5k mark. Once i change it, MDS kicks in and out smooth as butter again. I've read the oil acts as hydraulic fluid for the MDS lifters, and it makes sense now.I do mine when the OLM is down around 10%. This is typically about 6,000 miles of daily driving/commuting to work. I use Valvoline full synthetic 5w-20. I also use whatever oil filter Valvoline Instant Oil Change uses on their Full Syn O.C. package.
This alone would convince me to do shorter OCI's, as well as rethink the oil I was using. If the oil had degraded to the point that it affects MDS operation at only 5k miles I'd be worried about what else might be affected by that oil. I have no experience with Valvoline full synthetic oil, but I use Redline 5W-30 synthetic, and when I was actually doing closer to 10k mile OCI's I didn't experience any change in MDS operation between oil changes. I disable MDS now, but I've also switched to 5k OCI's.Update! I started doing 5k intervals, as I feel the MDS kick in much harder after the oil hits the 5k mark. Once i change it, MDS kicks in and out smooth as butter again. I've read the oil acts as hydraulic fluid for the MDS lifters, and it makes sense now.
If that's happening you need to stop getting that crap oil from an express shop. A real full syn oil will not be spent at 5k miles. You are getting shafted by them somehow or you are imaging mds being worse after 5k.Update! I started doing 5k intervals, as I feel the MDS kick in much harder after the oil hits the 5k mark. Once i change it, MDS kicks in and out smooth as butter again. I've read the oil acts as hydraulic fluid for the MDS lifters, and it makes sense now.
And how many miles/months is that?i do what blackstone recommends based on the analysis
Interesting Reports | Blackstone Laboratories
These are some of the interesting reports from gas and diesel engines, aircraft engines, transmissions, and more that we've done over the years.www.blackstone-labs.com
This is a really good report! This oil was run ~2,300 miles longer than the last sample, yet ironAnd how many miles/months is that?
I check my oil weekly. It’s always full and it’s still clean when I change it. That’s just wrong. Valvoline full synthetic oil is good oil. I used to use conventional barrel oil on my older trucks at 3,000 OCI and would get 300,000 miles on all of them.If that's happening you need to stop getting that crap oil from an express shop. A real full syn oil will not be spent at 5k miles. You are getting shafted by them somehow or you are imaging mds being worse after 5k.
Another thing is you might be burning oil and running very low if you are not checking it ever.
i just switched from OEM oil to Amsoil, my rep told me to change the Amsoil OE out along with filter at no more than 5,000 miles this first go round as the Amsoil will pull or clean all the deposits out of the engine. I will do this then switch to XL, as I personally believe this oil is far superior to OEM oil used. At that point I will follow 12,000 recommendations by Amsoil. I trust this oil and run it in my boat also. Converting everything I got to this oil. I know it’s a personal thing about oils. So just my view, if you have the hemi tick, that everyone talks about, give this oil a shot.I have a buddy who is buying signature series from me and has still been going by the oil life monitor in his vehicle, I don't understand it either....
However, after I use up my last change of OE I will be going to the XL line. It's a 12,000 miles change regardless of usage and the more towing I do with the trailer the more it will save me in the long run.
I have the same sentiment, premium synthetic oils have come a long long ways compared to oils from 20 years ago. But to each their own, people will still do what they want until you can convince them otherwise. I will still sell them the best oil.
Sent from my Moto Z (2) using Tapatalk
I bought my Ram a week ago; I have 115 miles on it, oil change indicator shows 97%, but my Ram app on my phone sent me an alert to see a dealership and change my oil within the next 500 miles or as soon as possible.+1 on that. Being a brand new vehicle...the oil change indicator has to "be broken in" so to speak. 10k-12k miles is Waaaay too many between oil changes, can't always go off of what the oil % is.
Assuming you bought it used, it's likely the previous owner changed the oil and reset the oil life monitor themselves. In which case the Ram app would have no idea that had happened. If you bought it new I don't have an answer for that.I bought my Ram a week ago; I have 115 miles on it, oil change indicator shows 97%, but my Ram app on my phone sent me an alert to see a dealership and change my oil within the next 500 miles or as soon as possible.
Nope. Brand new. 37 miles on it when I bought.Assuming you bought it used, it's likely the previous owner changed the oil and reset the oil life monitor themselves. In which case the Ram app would have no idea that had happened. If you bought it new I don't have an answer for that.
It's obviously an issue with the app. Sounds like it's time to contact the dealership about it or just ignore the app. Is there a way to just reset the app?Nope. Brand new. 37 miles on it when I bought.
dealer just wants you to spend money with them!Nope. Brand new. 37 miles on it when I bought.
