HAL9001
- Nov 10, 2020
I have a 2021 1500 Limited with the 5.7 Hemi. With the skyrocketing cost of gas, I've been using 87 octane gas (regular). I sometimes get occasional very light knocking only when the engine is in ECO mode (MDS) but other than that it runs great.
However, when I recently tried to pull my travel trailer that weighs around 8,000 lbs for the first time, I got moderately heavy knocking during acceleration. This of course is unacceptable. The owner's manual states:
"This engine is designed to meet all emissions regulations and provide satisfactory fuel economy and performance when using high-quality unleaded gasoline having an octane range of 87 to 89 as specified by the (R+M)/2 method. The use of 89 octane “Plus” gasoline is recommended for optimum performance and fuel economy".
So, it's rated to run on 87 octane but 89 (mid-grade) is recommended. I'll switch to 89 when towing the trailer and hopefully, that will cure the knocking.
Has anyone else seen this issue when pulling a heavy trailer? Will 89 be enough or do I need to switch to 91 octane (premium) for towing?
Any insight is appreciated.
