I just checked my equipment sheet and mine says "Big Horn non-BSG Lvl 2 Equip. Group " does anyone know if this "non-BSG" means something and is different from the regular level 2 equipment group?
Yep, I did a whole long post on all these missing items compared to the brochure. Early Lvl 2s didn’t get the inverter and plugs like they (you) should have gotten.Ok thanks, I'm going to talk with my dealer. I don't have 115 watt outlets either in the front or back, AND I'm not even sure if I have an inverter since none of this shows up on my build sheet even though it says I have the non-BSG lvl 2. I will keep you guys posted about what happens after speaking with the dealer.
Mine was built 6/18 and although it has Level 2 on the sticker, there is no AC outlets listed on the sticker whereas the website configurator says it is to receive them. Being it is not on the sticker, I really don’t have a leg to stand on but to be honest with myself, my 14 had it and I never used it.
How do you know when it was built? Bought it off the lot in June. It’s says lvl 2 package and charged me 2400 dollarsMy 2019 Bighorn was built the first week of December and has front and rear 110 outlets. It says that on the window sticker as well.
Hi Blazn, something is not right there... based on your sig block it appears you have already taken delivery of your 2019 BigHorn Ram in TX with Level 2 Equipment, is that right? According to the US brochure the BigHorn with Level 2 Equipment should have the 400W inverter, extra usb outlets, and 110v plugs front and rear.
Let’s see if I can attach the US brochure spec sheet (note H2 means BigHorn Level 2 Equipment). Can anyone else confirm that BigHorns with Level 2 are arriving without a 400w inverter and 110v outlets? Something sounds wrong there, maybe your dealer missed some of your options.
My order is for a similar truck, so I hope it is treating you well otherwise!
